Pillow ball upper mount
mattah
Postby mattah » Tue Jul 18, 2006 1:52 am
Better suspension response.. also adjustable for camber (and some also caster).
OMY005
Postby OMY005 » Tue Jul 18, 2006 8:39 am
mattah wrote:Better suspension response.. also adjustable for camber (and some also caster).
Cant see much advantage for a 5 as the shock/spring only goes up & down (double A arm) not rotating like a strut. All the camber and caster adjustment is done with the eccentric mounting of the bushes.
As for response; maybe a very slight difference as the standard top mount has some rubber in it.
Please correct me if I'm wrong. :oops:
Andrew. :)
Previously, White 95 NA 1.8 Hard Top,Stock standard
Now, 2016 Fiat 500x, 2014 Fiat 500, 2015 ND GT 2.0
Matty
Postby Matty » Tue Jul 18, 2006 11:41 am
Might give a bit better response, but I doubt you'd be able to pick it. Pointless with OEM bushings or shocks/springs still in place.
Might give a beesdick more bump travel?
