Understeer issues
bigdog
King of the kennel
Postby bigdog » Mon Jul 17, 2006 5:50 pm
If you've never done it yourself before and have no way of measuring the results accurately I wouldn't tackle that one trader. Way too easy to stuff it all up. If you have access to some measuring gear, or are familiar with the process of using level floor and string lines (very fiddly) to measure toe in/out then by all means give it a go, but don't rely on \"x turns = y mm toe in\" o do it, always measure the result.
trader
understeer issues
Postby trader » Mon Jul 17, 2006 11:13 pm
Thanks for the advice guys - will take it up with the workshop.
NB SE, NA 1.8.
