i have found that during some tight cornnering my interior lights are comming on. i supose this is because i'm getting excessive body flex? i own a '91 NA6.
do any other people suffer this issue? last time i drove it i found that the handbrake light is comming on around cornners too( this has only happened a couple of times).
i'm in the process of making my own body bracing, but i may also need the butterfly brace from FM too.
any comments?
body flex
- kitkat
- rvlovell
- Benny
- PT
In my old MX-6 Turbo the handbrake light came on when the brake fluid was low. Could be the same with the MX5
The interior light coming on could be the pin in the door jam.
Past:
2005 Mazda MX-5 SE
1991 Mazda MX-5 NA6
Past:
2005 Mazda MX-5 SE
1991 Mazda MX-5 NA6
- irwin83r
Re: body flex
butters wrote: last time i drove it i found that the handbrake light is comming on around cornners too( this has only happened a couple of times).
stop pulling the handbrake leaver
