Draining the box turret?
maxwolfie
Postby maxwolfie » Sat Jun 17, 2006 1:21 pm
Is there a way/point? I have some leftover redline that I want to chuck in there, but it's half full of murky crap
'89 JDM NA6 (black)
2" s/s ex., 4-2-1 extractors, high flow cat, RX-7 AFM + pod, lightened fly, h/d clutch, 2 way lsd, slotted rtrs, Racing beat type II front bar, Speedy 17" wheels
JBT
Postby JBT » Sat Jun 17, 2006 1:30 pm
You'd have to suck it out with a syringe or similar device. It doesn't hold much oil in there.
mightyrollaman
Postby mightyrollaman » Sat Jun 17, 2006 8:02 pm
Or you could just suck it out with a length of tube, then let it dribble out to a icecream container below.
The Rolla is mightier than the sword.
green_comet
Car Detailing Guru
Postby green_comet » Sat Jun 17, 2006 8:27 pm
i used my oil pump so suck it out, into a container..
bigdog
King of the kennel
Postby bigdog » Sat Jun 17, 2006 9:03 pm
*Pictures the Wolfman with mouth full of gear oil* :roll: :lol: :lol: :lol:
StanTheMan
Postby StanTheMan » Sat Jun 17, 2006 9:36 pm
bigdog wrote:*Pictures the Wolfman with mouth full of gear oil* :roll: :lol: :lol: :lol:
ROFLMAO.....too true
irwin83r
Postby irwin83r » Mon Jun 26, 2006 10:10 pm
trick is to stick the tube in fluid first and fill the tube, then plug both ends with your thumbs, then quickly let go of one end and cram it into the fluids deepest point then you should be able to put the end with your thumb on it still into a container at a lower point. this way you dont have to worry about coppin a mouth full might take a go or two to get used to, but after getting a mouthful of who knows what from an industrial pump i was tryin to drain before i stripped it when i was a first year i quickly realised theres gotta be a better... tasting way :roll: :P
