I have read on the forum that a AFR of 12.7 is ideal.
The technically correct AFR is 14.7
So is the 12.7 required for max power output ??
Under high loads ?
Thanks for your help.
Regards
Air Fuel Ratio ????????????
- Matty
Re: Air Fuel Ratio ????????????
Steve 818 wrote:
An AFR of 14.7 is the stoichiometric mix for petrol. In other words it is the most efficient ratio of air to fuel.
To clarify, stoichiometric means that there's exactly the right amount of air to combine with all the fuel and combust completely, with neither fuel nor air in excess. It's not the most efficient A/F ratio (that's somewhere around 16-17:1 IIRC)
- Alf
- Alf
THE REAL BORIS wrote:Have you seen the stock SE on a dyno re A/F ratio?
It's extremely lean, until by 3000 rpm it has enriched to 13:1 & by the time you see 4,500 rpm it is off the scale (and remains off) somewhere less than 10:1!!!
Yepp, seen mine today! Have chart in front of me. Mine's flat until 3k, then reduces in a straight line to reach 10 just below 4.5 as you say. I wonder just how far down it goes. If that line remains straight, it'd be down somewhere about 8:1 at 6500 rpm. Can't be good for economy.
Don't forget, though, that's under load and at full throttle. I'm sure the AFR increases when you reduce the right foot pressure.
Alf.
- Matty
12.5 then maybe even 12 I'd say.
I wouldn't trust that for a tune as far as I could kick a very fat elephant* .
*Note I am not Popeye, Hulk Hogan or the Incredible Hulk so I don't reckon I could kick an elephant very far at all.
'92, Red, Hardtop, Noisy CAI, Even more Noisy Exhaust, AVO Shocks with TJR Springs (Not so Fuli drifto speco).
- Astroboysoup
air fuel ratio??
Hi Tasroadster
My 1.6 NA has a JAM racing (non programable ECU) which last week showed on Dyno as AFR of 14:1 around 4000 rpm, and 12.0:1 WOT.
I am guessing that the manufacturer would have tuned it for optimum performance of a stock 1.6. Comments on this thread seem to agree.
NB SE, NA 1.8.
Users browsing this forum: Google [Bot] and 2 guests
