How can i tell if my engines been replaced?
JBT
Postby JBT » Sun Jun 25, 2006 10:45 pm
Top of block, rear, intake side. You'll need a bright light and something to clean the area to find the stamping.
rodent
강남 스타일
Postby rodent » Sun Jun 25, 2006 11:11 pm
JBT wrote:Top of block, rear, intake side. You'll need a bright light and something to clean the area to find the stamping.
THANK YOU! :D
I've been wondering about this for ages too.
jonno.
Postby Okibi » Mon Jun 26, 2006 2:10 am
Can you scan in the bit of paper?
JBT
Postby JBT » Mon Jun 26, 2006 9:15 am
JBT
Postby JBT » Mon Jun 26, 2006 9:22 pm
initial_mx5 wrote:I tried looking where the diagram says, i cant find it and theres to much...........
Look harder. There will be a flat deck on the rear of the block. The number is not stamped very deeply. Clean the area and get a very bright light. You may need to rub chalk on the flat area to help highlight the number.
Check the other (exhaust) side if you think it may be a BP engine.
sabretooth
Postby sabretooth » Tue Jun 27, 2006 8:30 pm
Follow the rear engine hook down and look for any flat planes. Get a rag and start rubbing where the flat plane is. The engine number should be there.
Juffa
Postby Juffa » Wed Jun 28, 2006 11:35 am
Come along to the club run this Sunday. There will be more than enough people there to hlep you find the engine number. By the way that number on the intake manifold is more than likely a part number and I believe that the piece of paper is as well.
J
sabretooth
Postby sabretooth » Wed Jun 28, 2006 11:40 am
initial_mx5 wrote:there is a small flat bit which kind of sticks out, it seems to just pop out from the engine with no use haha, rectangle or square in shape, would this be it?
It could be. Clean the dirt off it and see!
