I know that loose manifold nuts is a weakness on the SP, but can I retighten the offending nut, if so how do I get to it, and what risk am I taking driving it as is?
bigdog wrote:SO... driving home this afternoon and suddenly Marvin sounds like a tired Toyota Stout![]()
Close inspection reveals the centre lower nut on the exhaust manifold (to the engine block) has come loose, and I assume is either blowing past the gasket or has blown away some of the gasket. All the other nuts are tight and sweet, just the middle one is loose
bigdog wrote:All the other nuts are tight and sweet, just the middle one is loose
Craig wrote:The nut behind the steering wheel isn't that tight, nor sweet and he's certainly loose!![]()
sabretooth wrote:Craig wrote:The nut behind the steering wheel isn't that tight, nor sweet and he's certainly loose!![]()
Craig, some of your discoveries should be kept quiet, mmkay?
Craig wrote:Read it in a Maccas toilet in the Blue Mountains!
Sean wrote:You can just replace it (if the gasket is intact) but if it were mine I'd swap all teh studs out for inkonel (not sure of spelling) ones and ensure they are torqued perfectly. That's what i did on my AVO kit, hasn't lost a studs or nut since. I assume the same would work for SPs.
