100,000km service
Astroboysoup
Postby Astroboysoup » Wed Jun 21, 2006 11:46 pm
well please let this handsome young man help you out here.
umm i dunno
    timing belt
    other belts if need be
    oil
    oil filter
    brake fluid
    clutch fluid
    transmission oil
    diff oil
    air filter
    radiator flush
did i miss anything?
AustCars.net - It's like Facebook but for cars!
Astroboysoup
Postby Astroboysoup » Wed Jun 21, 2006 11:49 pm
maybe an older guy with more experience can help ya better.
I do all of that stuff myself in the garage and doesn't end up costing that much. Allows me to service the car more regularly to keep it in a better condition i recon
timk
Postby timk » Thu Jun 22, 2006 9:12 am
Where abouts are you located? Maybe someone can recommend a garage near you. I've got the American version of the '99 workshop manual, so if you want I can send you the details on the 60,000 mile service?
Matty
Postby Matty » Thu Jun 22, 2006 9:50 am
You should take the opportunity to replace the water pump while the timing belt is off.
JBT
Postby JBT » Thu Jun 22, 2006 10:28 am
Melissa wrote:Sorry, yes I'm a girl with not much experience in this area!
Start with a known reputable Mazda dealer or someone highly recommended by the folks here. Update your profile location for more help.
timk
Postby timk » Thu Jun 22, 2006 4:54 pm
Melissa wrote:Yeah if you could send the details of the 60,000 mile service that would be great!
Looks like a fairly major service:
60 Miles / 96 Kilometer scheduled maintenance for normal driving conditions
Engine
Inspect
- Engine valve clearance
- Tension of all drive belts
Replace
- Engine oil
- Oil filter
- Timing belt
Ignition system
Replace
- Spark plugs
Fuel system
Inspect
- Idle speed
- Fuel lines and hoses
- Houses and tubes for emission
Replace
- Air cleaner element
- Fuel filter
Cooling system
Inspect
- Cooling system
Chassis and body
Inspect
- Brake lines, hoses and connections
- Disc brakes
- Steering operation and linkages
- Front suspension ball joints
- Drive shaft dust boots
- Bolts and nuts on chassis and body
- Exhaust system heat shields
Replace
- Manual transmission oil
- Rear differential oil
Lubricate
- All locks and hinges
Air conditioner system (if equipped)
Inspect
- Refrigerant amount
- Compressor operation
Bevan
Postby Bevan » Thu Jun 22, 2006 5:07 pm
Most of those are inspections (which I wouldn't trust a dealer to actually do anyway). The only thing it says to actually replace is oil, oil filter, air filter and fuel filter.
Nothing about the timing belt that needs to be done. Maybe it's different for the states?
CT
Postby CT » Thu Jun 22, 2006 5:07 pm
Hi Melissa, I have used McGraths for a couple of things and found them to be OK - they are at Kirrawee. Apart from that, not sure, I haven't used Rockdale Mazda before - anyone else?
timk
Postby timk » Thu Jun 22, 2006 5:19 pm
It says to do the timing belt as well, it's just that I had to hand copy the list and I skipped a line since it was listed in a different spot, my bad!
Garry
Postby Garry » Fri Jun 23, 2006 9:59 am
Has anyone had any prices for a 100000km dealer service on a NB8B? It cost me just over $1000 for my NA service wich included a water pump. But the NB requires a valve clearance check as well which wouldn't be cheap. The time is fast approaching for the SP 100000km service.
jules
Guitar Hero
Postby jules » Wed Jun 28, 2006 2:25 pm
$800-$1000 depends if you do the water pump (WHICH YOU SHOULD).
We had a dodgy day up here in Qld on the weekend to do this service for Mikey. I think he got away with about $370.00 for parts and a keg of Heinekin
Jules
Uncle Arthur
Dodgy Award Benefactor
Postby Uncle Arthur » Wed Jun 28, 2006 7:35 pm
jules wrote:$800-$1000 depends if you do the water pump (WHICH YOU SHOULD).
Jules
Yep - what he said.....
I regularly do my own servicing, and so I know what's been done and when.
For the recent dodgy weekend the work basically included:
timing belt replace
water pump replace
service timing tensioner wheels
reset timing (14 Deg BTDC)
check and reinstall spark plugs (still fine)
tappet cover remove and reinstall (new gasket goo - reuse old undamaged gasket)
New oil and filter
new coolant
Prior to this I had already in separate services:
replaced thermostat
replaced drive/accessory belts
replaced brakes front and rear
replaced gearbox oil
replaced diff oil
serviced airfilter (K&N)
checked coolant hoses and replace where necessary
So yes, for the equivalent of a 200000km service, I did the top list. Cost was $308 for new parts, plus some tools I needed, and food + beer for da boyz - about $400 all up.
If you have access to space, tools,and knowledgeable help, and are able to or know someone who can happily work on cars, then it isn't too big a deal to do your own services - even seemingly major ones.
