Brake Pads ?
- Kvision
Brake Pads ?
Hi guys,
need new brake pads for my 1993 1.6
Im after something streetable that I can depend on when I go for a spirited drive in the twisties, and also last a few laps on the track. I dont plan to go on track all that often, maybe once or twice a year, so the vast majority of driving is done on the street/twisties.
I think i need something along the lines of these
high performance
can stop well cold or hot
doesnt not chew up the rotors
reasonable pad wear
not too much dust
not too much noise
not too much $$
I've read the many threads here and on the old forums and I think I've narrowed it down to either the Hawk HPS or Bendix Advance (the advances seem to be the cheaper option at a little under $120 for all 4 corners). Which one would be more suitable to my needs?
high performance
reasonable pad wear
not too much dust
not too much noise
not too much $$
Re: Brake Pads
Kvision wrote: ..Bendix Advance (the advances seem to be the cheaper option at a little under $120 for all 4 corners).
I have put these on the Front along with new rotors and I dont think there is any more dust than previously. I havent put them under real pressure yet and they work well.
Richard
Mazda Tribute - its a boat
Coming - Jayco Eagle wind up camper - woo hoo
Ex cars 2007 NC LE Radiant Ebony, 1990 Eunos Neo Green LE
- RobbieRat
- Kvision
mightyrollaman wrote:Sounds like you'd be best sticking to stock. I'd hate to be cleaning any more dust off your wheels.
What's the latest pal? Still keen for a photoshoot? I am.
Hey, I'm still up for a photoshoot after I finish my exams next thursday. Maybe organise a little cruise too...
RobbieRat wrote:(the advances seem to be the cheaper option at a little under $120 for all 4 corners).
That would be for each end not corner![]()
With pads you pretty much get what you pay for and having said that, the stock pads are pretty good and won't fade on the track.
well, from discpads they are $60 for the front, $40 for the rear and another $15 for shipping. So do you think that the advances would be ok at the track then?
- Kvision
- Kvision
Ultimates leave a lot of dust, thats why I tried the Advance.
There has to be better than both these pads.
That said i'm not too happy with my brakes at the moment, probably need new rotors and a good fluid flash.
- Matty
- CT
When you pay $60 for a set of pads, you can't expect they are decent for anything but driving to the shops - sometimes not even that. Good pads cost good money - as with everything. Hawk HPS is the first step to better pads, then if you want a more dual purpose track/road pad, check out Hawk HP Plus. They have also introduced a ceramic which my tech contact at Hawk reckons is a good thing with excellent cold performance so is well suited for MX5s.
There's my sponsors plug done. I really like Ferodo DS2500s for dual purpose and Matty likes the Cobalts - these are all very good pads. Once you have experienced a decent pad, you will not go back to cheap crap.
http://www.hawkperformance.com/performa ... eramic.pdf
http://www.hawkperformance.com/parts/se ... rts+%3E%3E
Here's the Cobalt GTs
http://www.cobaltfriction.com/productcart/pc/viewPrd.asp?idProduct=29359
http://www.cobaltfriction.com/productcart/pc/viewPrd.asp?idProduct=31937
Who sells them in Australia?
- Kvision
- irwin83r
i hear that bendix use a laminate or something in their pads which is said to be bad for slotted or drilled rotors?? anyone know any more on this or should i ring my brake guy and get him to explain it more slowly to me this time
anyone tried QFM? (queensland firction mats) apparently they are looking to be a good australian brand up and coming with a track back ground.
