quick suspension question - can you kindly answer please
ralphie
Postby ralphie » Wed Jun 14, 2006 12:51 am
upper control arm long bolt
NB8B mx5 front suspension
can someone tell me where it is?
i am just staring at all the bolts and cant figure which one it is...
Babalouie
godfather of saké
Postby Babalouie » Wed Jun 14, 2006 1:09 am
If you're asking it in the context of shock removal, then it's the one that is to the left of the leftmost red arrow. It's the longitudinal bolt that the top wishbone pivots around. It's quite long, so I think you have to loosen the sway bar mount to get it out all the way.
ralphie
Postby ralphie » Wed Jun 14, 2006 1:17 am
you mean the bolt that appears lighter in the picture? almost a gold like color
i thought that was the upper a arm :oops:
massive bolt...
ralphie
Postby ralphie » Wed Jun 14, 2006 1:22 am
as in the bolt that goes through the top 2 bits as in picture below?
it wont budge
Matty
Postby Matty » Wed Jun 14, 2006 9:28 am
ralphie wrote:you mean the bolt that appears lighter in the picture? almost a gold like color
massive bolt...
The gold thing is the washer under the head of said bolt. The bolt is probably 20cm long, if not more, it goes through the two uper inner control arm bushings.
Yes you have to unbolt the sway bracket to remove it. If it's stiff, schwing der big hammer.
Babalouie
godfather of saké
Postby Babalouie » Wed Jun 14, 2006 12:09 pm
massive bolt...
Yup...that's the one! If you're doing a shock change, then removing the top arm is a difficult/hardcore way to go about it IMHO. That top bolt will be the devil's own work to get out...
IMHO, the "San Diego Miata Club Method" is a lot easier for the front: http://www.sandiegomiataclub.org/sdmc/g ... hocks.html
ralphie
Postby ralphie » Wed Jun 14, 2006 1:26 pm
ok
thanks heaps for the help
helped me big time
cheers
Users browsing this forum: No registered users and 145 guests
