Speedo Accuracy
- tinsfci
- Vehicle: NA - V8
Speedo Accuracy
I spent half the weekend changing the 4.1 open diff on my NA8 for a 4.3 Torsen and was expecting the speedo to be out after the change. To my suprise the speedo seems to be spot on (I am guessing the tacho is correct, and I used a gear calculator to check speed at different RPM). I can only guess that the speedo was reading slow before (odometer was about right before the change based on km posts on a long trip last weekend).
So, has anyone else had issues with speed accuracy before, and can it be tweeked to read correctly and still have the odo read correct too?
Also, if most of the NA speedos read low, how do you poor buggers in the Eastern Block survive all of those fixed speed cameras?
ps. Torsen diff rocks!
Street='94 with FFS Coldside. Sold
Race='97 with AVO (soon to be Absurdflow) and GT2560 <--- sod that... LS1 conversion underway!
- StanTheMan
- AJ
changing the diff ratio won't affect your speedos accuracy, it only changes the ratio of revs at the same speed up or down......................the only major factor in speedo accuracy is if you change the rolling diameter of your wheels & tyres
XMX5 Rogues
- RRdstr
AJ wrote:changing the diff ratio won't affect your speedos accuracy, it only changes the ratio of revs at the same speed up or down
Mmmmm . . . I haven't had my coffee yet . . . and I'm not getting any younger . . . are you sure? . . .
Rex
JBT wrote:My MX-5 speedo over reads by 5% (105 indicated = 100 true).
likewise...
- chrislevingston
My GPS receiver tells me that 60kmh indicated on the speedo is 58kph.
Funnily enough, the Calais is exactly the same.
1990 "TOY MX5" - Red, of course!
Kings, Konis, LSD, Genie system, grille, Voodoo knob, braces, 14 degrees ATDC, woodgrain dash,style bars and lots of work making the rubber bands go around faster.
- godfather of saké
- bigdog
- King of the kennel
AJ wrote:changing the diff ratio won't affect your speedos accuracy, it only changes the ratio of revs at the same speed up or down......................the only major factor in speedo accuracy is if you change the rolling diameter of your wheels & tyres
Too much birthday bourbon AJ??
Babalouie wrote:What size tyres do you use?
I went from 4.1 to 4.3 in my NA8 too, and it always feels like the speedo is over-reading. If I sit on the freeway at an indicated 115km/h I get overtaken all the time
Babs, not sure if you meant JBT & myself, but my drive train, wheels & tyres are all stock NA8 - indicated 115 is actually 110 for me. I believe JBT went 'plus 1' with his wheels & tyres.
- bigdog
I should have added that an increase in the rolling diameter of your wheel/tyre combination on the rear will result in an increase in actual speed, while a decrease in overall diameter will have the opposite effect (but will allow the car to accelerate quicker - hillclimb cars often use smaller dia rear wheels for this reason).
- tinsfci
- Vehicle: NA - V8
I run 195/50/15, but this was taken into account by the gear calculator. If the speedo is correct now then it must have been reading slow with the 4.1. On the weekend i will go and find some km marker posts and check the odometer. Will check the speedo at the same time with a GPS. The thing that really worried me is that I drove ~1000 km last weekend on a double demerit point weekend sitting on just the wrong side of the limit. If my speedo was out, then I was real lucky not to get pinged.
- JBT
- Noodle
Speedo Accuracy
Is there a corresponding speedo cable gear reduction we can buy when going from a 4.1 ratio diff to a 4.3 ?
My current speedo with 4.1 diff already reads fast (115km/hr indicated when travellling 110km/hr), going to 4.3 diff would make indicated speed even faster.
