What Wheels? NA6
Robbo107672
What Wheels? NA6
Postby Robbo107672 » Sun May 28, 2006 10:02 am
Hi, I'm looking for a set of wheels for my NA6 which has some aftermarket 14' Mags on it now.. Not too happy with the looks and the rear tyres are not too far away from needing to be replaced.
I'm interested in some 15's or 16's and was wondering what Offset, weight and size etc that I should be looking for.
I use the MX5 as a daily driver with the odd 'Spirited' drive, very occasional track run and I want some comfort, so will the 16's be too much ? (I have just fitted Koni/Kings and am very happy with it after a drive thru the Dandenongs the other day. The old shocks were completely stuffed.)
I like the HR Racing HR125's & HR126's for appearance but have not been to the store to talk about their characteristics yet.
http://www.mswt.com.au/products_closeup.asp?part=HR+RACING&part_no=24
[/url]
Thanks in advance, Rob.
Robbo
[strike]Laguna Blue NA6, NB Titanium SE, 1993 Red NA6, 1990 BRG NA6[/strike], Granpa Grey NC1
MX5 #5, an NC series 1 this time !
kitkat
Postby kitkat » Sun May 28, 2006 8:38 pm
What colour is your car?
if your worried about comfort prob better off going 15\" with a higher profile (also the tyres are cheaper) and there isnt much of a range in 16\" from what i hear.
so after saying that maybe a 15 x 7 (should fit 215 or 225 i think) with a 30mm offset i guess, maybe someone else can confirm an offset.
StanTheMan
Postby StanTheMan » Sun May 28, 2006 8:43 pm
Rob.
In my opinion the 16 will look drop dead gorgeous.
But tread carefull. Most like ly the offsett will be 35mm. Which would make it legal.
Check the weight......I drove with some really light wheels the other day & it makes a huge difference. (nothing new here just never had a chance before)
Also Agressive street rubber will be much harder to get fort the 16 inch rim. Believe me. but if you are getting the standard run of the mill.....Great.
Drifters tend to use 15\" rims & everything under the sun is avail.
LAst but not least. the 16 inch rim will be illegal . if you drive an early NA.
however you may not be too concerned about 0.5\"
Shadow
Postby Shadow » Mon May 29, 2006 9:05 pm
tangent: why does the 16\" become illegal on NA's??
'90 Eunos Roadster V-SPEC. Tan Leather, British Racing Green.
StanTheMan
Postby StanTheMan » Mon May 29, 2006 9:44 pm
you may not care, and it only minor, but those particular 16\" rimms are 7 inch wide...early NA's are 5.5\" wide from the factory. You can inrease yor width by 1 inch without getting certification or engineering. No big deal its only 0.5\" over. you could do a lot worse. :D just pointing it out. so now you know....
Robbo107672
Postby Robbo107672 » Mon May 29, 2006 10:59 pm
I'm thinking that I want 15x6.5's but I do like the look of the 16's.
Have seen some second hand Mazda wheels at Mania that may interest me in 15 x 6.5 but will have to look into the off sets of the after market ones & weight etc.. before I make a decision.
Assuming that standard offset on early NA's is 45mm for 14 x 5.5inch according to Miata.net.. If I go up to 15 x 6.5, should the offset remain 45mm assuming the over all rolling diameter is the same? Does anyone know ?
ps. To answer kitkat question, I have a 1990 Laguna Blue NA6
Ref: http://www.miata.net/garage/offset.htm
Robbo
kitkat
Postby kitkat » Mon May 29, 2006 11:49 pm
have you ever thought about putting white wheels on? White + Blue goes very well!!!
I think the offset would be reduced to something around 35mm im guessing?
sab
Postby sab » Tue May 30, 2006 9:50 am
Here's a pic of the HR125's on my car. Size is 16x7.
Thinking of changing wheels soon, so may be for sale!
atomic
Postby atomic » Tue May 30, 2006 2:14 pm
sorry, a bit off topic but just wondering if the steering gets a lot heavier with the larger wheels
I'm talking about non-powersteering...
sab
Postby sab » Tue May 30, 2006 3:41 pm
atomic wrote:sorry, a bit off topic but just wondering if the steering gets a lot heavier with the larger wheels
I had bigger wheels on my NA6 and yes. The steering does get a little heavier, particularly when parking. :frown:
A power sterring upgrade sorted that problem out! :mrgreen:
bam Posted: 30 May 2006 02:05 pm Post subject:
sweet ride sab
Thanks bam :P
rvlovell
Postby rvlovell » Tue May 30, 2006 4:13 pm
When I put 16's on my NA the car lost its direct feel with the steering and the ride got harder. Not to the extent that it ruined the car but it was diferent. It looked bloody good though. I havn't had trouble with getting tyres in 16\" but they will cost the same as 17\" tyres.
Back to having no money, damn my obsession.
Robbo107672
Postby Robbo107672 » Wed May 31, 2006 8:09 pm
Very nice look Sab !
The offset looks ok, still under the guards.. Let me know if they go up for sale!
Robbo
StanTheMan
Postby StanTheMan » Sun Jun 04, 2006 11:31 pm
thats what i have currently.
i run 205/50x15
no probs there at all. unless you've dumped it super, super low.
rimms are 15x6.5 offset is 35mm
here is what it looks like Image
another angle
FUN-29T
Postby FUN-29T » Mon Jun 05, 2006 11:54 pm
Personally I'd prefer 15's for my NA when it comes to performance, handling and comfort.
