Door speakers NA8
- Brad
I have JL Audio 6\" splits which fit perfectly. The tweeters are tied to the air vents in the corner of the dash by little zip ties which are under the tweeter and allow it to sit flush.
Most decent 2-ways of this size are 6\". You won't see any real benefit from a 6.5\".
- Astroboysoup
spend the extra money and get the splits.
much better quality and better sound. you won't regret it but it does cost a bit more.
I spent $300 on a pair of DLS splits.
http://cgi.ebay.com.au/DLS-Ultimate-UR6 ... dZViewItem
AustCars.net - It's like Facebook but for cars!
- sab
- Astroboysoup
possible.. you'll need to dremel a bigger whole in the door frame to mount the speaker.
you'll probally want to make a MDF ring to mount the speaker on to as well.
and i don't know about the mount depth... you might be lucky witha cheaper 8\" speaker but anything with a mig magnet might not fit in the door.
you'll then need to cut in to the door panel to make it all nice.
maybe alot of sound dampening too to keep the door from vibrating like crazy too....
hmmm
i might try it.
hmmm
i might try it.
- kitkat
8\" go in the rear shelf...
ive put 6\" in the rear and it sounds great even with the top down.
here's the write up from miata.net
http://www.miata.net/hakuna/subspeak.html
- Brad
I run mine off the headunit for about a year until I bothered to put a 4x30w amp in and BOY does it make a HUGE difference. The Headunit was by no means underpowered (45x claimed) but in reality this is only around 10w RMS and the dynamic range is much less. If you have an amp or can afford one get it.
- JBT
- sabretooth
The SQ increase I got by changing to an aftermarket headunit (from the standard cassette deck) was noticeable - and then the SQ increase again from going to that to the amp was even more noticeable. My problem at the moment with my Jaycar splits is that I have nowhere to mount the tweeter, and they rattle the crap out of the door trim!
- jules
- Guitar Hero
- sabretooth
- jules
- Guitar Hero
- sabretooth
- Brad
sabretooth wrote:I just got some plastic sheeting I had lying around. I put it behind the speaker and sort of wrapped it and used the speaker to hold the plastic there between the speaker and door.
