I used an Autorotor on my old mans NA6
we high mounted it above the Extractors
If i had a choise I would go turbo The install is easyer
benoz wrote:So where did you get the intake manifold?
benoz wrote:Pity cos superchargers have far better power delivery!
the roadster wrote:Woo wrote:benoz wrote:Pity cos superchargers have far better power delivery!
I beg to differ on that score.
Turbos are not as rev dependant as a supercharger and are capable of making much more power.
Wòó
No,it's the other way around.
A turbo need to wait for pressure (ie rev) to build up to drive the turbine,whereas supercharged dríven by the crank-shaft boost-up from idle.
In regards to power (turbo or super-charge),depend how much boost you motor can withstand the pressure (usually by lots of $$).
the roadster wrote:No,it's the other way around.
