Newbie question - suitable engine swaps
- sabretooth
Hangon, what are you using the BPT for? I'm just asking as I want to make sure you want it for the block and not because it's a turbocharged BP - you can't use the IC pipes, the intake manifold, the exhaust manifold - so all you're getting is the BP-1 block and BP26 head. The sodium-filled exhaust valves are only on the GTR engines - and if you can find or even afford a GTR engine, then there are cheaper and better ways of getting sodium-filled exhaust valves and 8.2:1 pistons.
If you're putting a BPT into an NA6, then I hope you have 1.8L engine bits handy. You'll need em. BPTs are FWD and BPs are RWD - so mounts, the CAS, manifolds, sump, oil pump and other gear are all different.
- sabretooth
- sabretooth
- sabretooth
- DanielB
You don't have to run a BOV. It's only function is to prevent compressor surge, which is caused when compressed air between the turbo and throttle body gets sent back out through the turbo, due to the butterfly on the throttle body being closed suddenly on releasing the throttle and having nowhere else to go.
DanielB wrote:You don't have to run a BOV. It's only function is to prevent compressor surge, which is caused when compressed air between the turbo and throttle body gets sent back out through the turbo, due to the butterfly on the throttle body being closed suddenly on releasing the throttle and having nowhere else to go.
yep but isnt that bad for the turbo?
- Sean
DanielB wrote:It's only function is to prevent compressor surge, which is caused when compressed air between the turbo and throttle body gets sent back out through the turbo, due to the butterfly on the throttle body being closed suddenly on releasing the throttle and having nowhere else to go.
It can also sound fully sik bro
glen73 wrote:DanielB wrote:You don't have to run a BOV. It's only function is to prevent compressor surge, which is caused when compressed air between the turbo and throttle body gets sent back out through the turbo, due to the butterfly on the throttle body being closed suddenly on releasing the throttle and having nowhere else to go.
which is why you "should" have a BOV...
but you don't -need- to run one.
More relevant to a Manual too as a BOV means the compressor is not slowed down during gear changes (in an auto it doesn't matter because the engine is constantly working)
