What Wheels? NA6
What Wheels? NA6
Hi, I'm looking for a set of wheels for my NA6 which has some aftermarket 14' Mags on it now.. Not too happy with the looks and the rear tyres are not too far away from needing to be replaced.
I'm interested in some 15's or 16's and was wondering what Offset, weight and size etc that I should be looking for.
I use the MX5 as a daily driver with the odd 'Spirited' drive, very occasional track run and I want some comfort, so will the 16's be too much ? (I have just fitted Koni/Kings and am very happy with it after a drive thru the Dandenongs the other day. The old shocks were completely stuffed.)
I like the HR Racing HR125's & HR126's for appearance but have not been to the store to talk about their characteristics yet.
http://www.mswt.com.au/products_closeup.asp?part=HR+RACING&part_no=24
[/url]
Thanks in advance, Rob.
[/url]
Robbo
[strike]Laguna Blue NA6, NB Titanium SE, 1993 Red NA6, 1990 BRG NA6[/strike], Granpa Grey NC1
MX5 #5, an NC series 1 this time !
- kitkat
What colour is your car?
if your worried about comfort prob better off going 15\" with a higher profile (also the tyres are cheaper) and there isnt much of a range in 16\" from what i hear.
so after saying that maybe a 15 x 7 (should fit 215 or 225 i think) with a 30mm offset i guess, maybe someone else can confirm an offset.
- StanTheMan
Rob.
In my opinion the 16 will look drop dead gorgeous.
But tread carefull. Most like ly the offsett will be 35mm. Which would make it legal.
Check the weight......I drove with some really light wheels the other day & it makes a huge difference. (nothing new here just never had a chance before)
Also Agressive street rubber will be much harder to get fort the 16 inch rim. Believe me. but if you are getting the standard run of the mill.....Great.
Drifters tend to use 15\" rims & everything under the sun is avail.
LAst but not least. the 16 inch rim will be illegal . if you drive an early NA.
however you may not be too concerned about 0.5\"
- Shadow
- StanTheMan
you may not care, and it only minor, but those particular 16\" rimms are 7 inch wide...early NA's are 5.5\" wide from the factory. You can inrease yor width by 1 inch without getting certification or engineering. No big deal its only 0.5\" over. you could do a lot worse. just pointing it out. so now you know....
I'm thinking that I want 15x6.5's but I do like the look of the 16's.
Have seen some second hand Mazda wheels at Mania that may interest me in 15 x 6.5 but will have to look into the off sets of the after market ones & weight etc.. before I make a decision.
Assuming that standard offset on early NA's is 45mm for 14 x 5.5inch according to Miata.net.. If I go up to 15 x 6.5, should the offset remain 45mm assuming the over all rolling diameter is the same? Does anyone know ?
ps. To answer kitkat question, I have a 1990 Laguna Blue NA6
Ref: http://www.miata.net/garage/offset.htm
Robbo
- sab
- sab
atomic wrote:sorry, a bit off topic but just wondering if the steering gets a lot heavier with the larger wheels
I'm talking about non-powersteering...
I had bigger wheels on my NA6 and yes. The steering does get a little heavier, particularly when parking.
A power sterring upgrade sorted that problem out!
bam Posted: 30 May 2006 02:05 pm Post subject:
sweet ride sab
Thanks bam
- rvlovell
When I put 16's on my NA the car lost its direct feel with the steering and the ride got harder. Not to the extent that it ruined the car but it was diferent. It looked bloody good though. I havn't had trouble with getting tyres in 16\" but they will cost the same as 17\" tyres.
Back to having no money, damn my obsession.
- StanTheMan
Users browsing this forum: No registered users and 140 guests
