AJ wrote:which is the same no matter WHICH model you drive
Isn't the SP heavier at the front because of the bigger turbo?
Boyracer wrote:AJ wrote:which is the same no matter WHICH model you drive
Isn't the SP heavier at the front because of the bigger turbo?![]()
jules wrote:or get an SP and slap some shocks and an LSD in. Might be easier/cheaper.
THE REAL BORIS wrote:It was an unbiased question; I thought it was 108rwkw SE to 120 rwkw SP.
Mazda seemed to have underated the SE by only claiming 121 flywheel kw & the SP seems to have lost heaps in the transmission if we are to believe 157 flywheel kw.
The Mazdaspeed dyno figures agree with the SE figures i.e. 178 flywheel and 145 rwhp (108rwkw).
