hey guys when im driving the ol mx-5 sometimes if i go over a bump or place my phone in the tray below the head unit, it switches off and i have to turn it back on, it even happens when i clean the car, could this be somthing major? or something little like a loose wire ?
thnx guys
Electrical Problem ?!?!
- FUN-29T
- JSE
- Bevan
If it's 2000 model and it cuts out, chances are your aftermarket wiring is just band-aided up instead of soldered or crimped together.Crocaine wrote:i forgot to mention its a 2000 model
You can fix it yourself. Buy some tab connectors and when you take the headunit out, only take one wire out at a time and crimp a female on one end and a male on the other end. Doing it one by one will make sure you don;t get the wires mixed up.
Re: Electrical Problem ?!?!
Crocaine wrote:hey guys when im driving the ol mx-5 sometimes if i go over a bump or place my phone in the tray below the head unit, it switches off and i have to turn it back on, it even happens when i clean the car, could this be somthing major? or something little like a loose wire?
with my mobile phone in the holder below the headunit i get interference through the speakers at the same time every hour from the mobile network check. given the other times your problem happens i.e. cleaning (assuming you're using an electrical appliance, so maybe interference again) & over bumps, it could be a combination of wiring & interference from electronic devices.
