limiter
rodent
강남 스타일
Postby rodent » Sat May 20, 2006 1:31 am
StanTheMan wrote:giving it a little stick to me means get it up to 5k firmly but gently.
not pedal to metal.
Ah :oops:. Thanks for clearing that up :D.
StanTheMan wrote:when i say 1/4 I also mean the needle at quater of 100% on the guage. which means its almost at operating temp.as the needle sits on 50% on the guage. at normal operating temp.
Yep, but isn't the thermostat still closed(?) at that point and oil pressure still highish? Does that matter?
Sorry for the silly q's - I'm still learnin' :)
jonno.
StanTheMan
Postby StanTheMan » Sat May 20, 2006 8:45 am
don't know. I've been doing it for years
AJ
Postby AJ » Sat May 20, 2006 9:19 am
9 times out of 10 if your gauge is up towards the 1/4 mark rodent, the thermostat has already started to open 8)
XMX5 Rogues
rodent
강남 스타일
Postby rodent » Sat May 20, 2006 12:07 pm
Cool. This should really speed up my warm-up routine then. Thanks for the great info :D.
jonno.
StanTheMan
Postby StanTheMan » Sat May 20, 2006 12:08 pm
rodent wrote:Cool. This should really speed up my warm-up routine then. Thanks for the great info :D.
jonno.
don't forget.....its not about speeding up the warm up process. its about making the engine run smoother
AJ
Postby AJ » Sat May 20, 2006 4:37 pm
i reckon ya tacho needs recalibrating somehow.........LOL :lol: :lol:
XMX5 Rogues
StanTheMan
Postby StanTheMan » Sat May 20, 2006 4:40 pm
tough question. opinions will vary quite a lot.
when going hard i try to conciously change at 6500 rpm
however in a recent video i realised i go to 7000 rpm on the regular basis without realising. I've personaly only hit the revlimiter conciously a handfull of times. Add half a handfull of times accidently in 10 years of driving this MX5.
other drivers are quite happy to hit the revlimiter any time anywhere.
AJ
Postby AJ » Sat May 20, 2006 5:32 pm
well for me stan, i've never hit the limiter yet, & have no intention of doing it either, not because i'm a sook, simply because these little cars hit their peak power WELL before the rev limiter cuts in, so to me, it's just a waste of fuel & time in a standard car.........if i'm stripin' it, i too shift @ 6500.....again, that's just me 8)
XMX5 Rogues
Shadow
Postby Shadow » Sat May 20, 2006 8:11 pm
where abouts do the mx engines hit their peak? assuming standard engine.
most of my driving would probably take place below 6k.
but then compared to some people around here i would fit into that sook category. i don't trust myself enough to be able to get out of situations i'm likely to put myself into. nor do i know how far i can push it before its *too* far.
'90 Eunos Roadster V-SPEC. Tan Leather, British Racing Green.
