Cold Air Intake Headlight Covers - For NA
- Mr_Q
JSE wrote:i assume craigs talking about cutting a hole right next to the water container for the wipers
The hole actually goes pretty much right where the water bottle normally sits:
(the Mania CAI is just the bit from the firewall to the air-flow metre thingo)
Water bottle gets moved, hole gets cut and cold air gets pushed down the windscreen and straight into the air intake.
I believe Mania do have an NB CAI but it's a completely different design.
Mister Q
Had: Red 2004 SE, Red 1993 NA8 Clubman, Green 1991 NA6 LE
- Cal
- Mr_Q
Cal wrote:Keep in mind that if you ever intent to race the car, CAMS will not allow a hole in the firewall.
Is the location of the hole technically in the firewall as far as CAMS is concerned? There is still solid metal bodywork between the engine bay and the cabin.
Mister Q
- Cal
