SP or SE
Which OEM Turbo MX-5 Do You Prefer - SP or SE
Poll ended at Mon Jun 05, 2006 1:40 pm
SE
32
48%
SP
34
52%
Total votes: 66
Boyracer
MX-5 Encyclopedia
Postby Boyracer » Wed May 10, 2006 8:54 am
AJ wrote:which is the same no matter WHICH model you drive :mrgreen:
Isn't the SP heavier at the front because of the bigger turbo? :roll: :roll:
Garry
Postby Garry » Wed May 10, 2006 10:04 am
I'm not sure about the SP but it probably is because the whole 22kg or whatever extra it weighs is pretty much all located at the front. The SE will have some of it's extra weight negated by the torsen diff at the rear However the NA is the most front heavy of all the proper production MX5's because of the pop up light hardware.
With every new model Mazda says that the new car now has a 50/50 weight distrubution. Maybe they have the same problem reading weight scales as they do with dyno charts. :roll: It's either 50/50 or it's not I would have thought.
AJ
Postby AJ » Wed May 10, 2006 5:15 pm
shitstirrer :lol: :lol: :lol:
XMX5 Rogues
JBT
Postby JBT » Wed May 10, 2006 7:10 pm
Why isn't there a third option?:
neither
AJ
Postby AJ » Wed May 10, 2006 7:33 pm
coz that'd show that the majority don't give a rats JB :lol: :lol: :lol:
XMX5 Rogues
RG.net
Postby RG.net » Wed May 17, 2006 5:50 pm
im just glad i have a MX-5 :P
MX5-SP
Postby MX5-SP » Fri May 19, 2006 3:50 pm
jules wrote:or get an SP and slap some shocks and an LSD in. Might be easier/cheaper.
Jules,
...now why the hell would anyone want to fit a LSD to a SP?
:roll:
Snow White: Torsen 3.9 LSD, A/Sway Bars, R/Bar Plus Clear Reflectors!
jules
Guitar Hero
Postby jules » Tue May 23, 2006 11:45 am
Look at your sig \"Wally\".
:lol: :lol: :lol: :lol: :lol: :lol:
Jules
Postby Okibi » Fri May 26, 2006 10:49 pm
As an MX-5 owner i'm sure you can appreciate that power isn't everything.
A lot of different elements go into making the complete package.
It’s interesting to see how people weigh up the differences between the two cars and decide which package they prefer.
Postby Okibi » Sat May 27, 2006 1:45 am
Casey
Postby Casey » Sat May 27, 2006 2:02 am
THE REAL BORIS wrote:It was an unbiased question; I thought it was 108rwkw SE to 120 rwkw SP.
Mazda seemed to have underated the SE by only claiming 121 flywheel kw & the SP seems to have lost heaps in the transmission if we are to believe 157 flywheel kw.
The Mazdaspeed dyno figures agree with the SE figures i.e. 178 flywheel and 145 rwhp (108rwkw).
At the risk of being accused of SE bashing yet again, those SE dyno figures have always been questionable. Why? Well they always seem to be quoted from a non-dyno dynamics or a hub dyno. The in-gear figure would also probably be biased towards the SE on a direct comparo due to its lower final drive making the SE ATW figure seem higher compared to the SP gear for gear - hopefully someone can set me straight.
The SP figure seems about right - around 30% seems to be widely accepted as normal driveline loss (the SP was rumoured to actually be a bit fitter then Mazda's insurance friendly 150kW) and my own SP recorded a figure in that range when on two different dyno dynamic dynos (136kW ATW after some ChipTorque finessing).
Anyway, there are lies, damn lies and dyno figures.
I guess the real test is in the standing start times. Using reputable magazine figures (two up, half a tank of juice I guess), the times are:
SP - 0-100km/h 6.46s 0-400m 14.74s
SE - 0-100km/h 7.39s 0-400m 15.33s
I seem to remember in the S2000/200SX/SP comparo though the SP was closer to a flat 14s 0-400m???
White SP Image
Boyracer
MX-5 Encyclopedia
Postby Boyracer » Sat May 27, 2006 8:10 am
Dyno day we had a while ago.
My stock SE...106kw.
Dazs' stock SP...121kw.
Same dyno,same day.
ASE05
Postby ASE05 » Sat May 27, 2006 9:11 am
MY SE - CHIPTORQUE DYNO = 106.5RWKW
StanTheMan
Postby StanTheMan » Sat May 27, 2006 9:28 am
you will always get a slight varience between cars of the same model. even on the same day. If you get 5kw ATW variation between stock NA6A's you'd have to expect the same or more for cars twice thier KW.
maybe your motor was buitl on a Mon.
PT
Postby PT » Sat May 27, 2006 11:01 am
My SE stock, 109.5rwkw
Remove the intake snorkel, 112rwkw
Past:
2005 Mazda MX-5 SE
1991 Mazda MX-5 NA6
