Shockers.
Shockers.
Hey,
I'm a bit of an amateur when it comes to cars, but I was just after some advice on some new shockers to get for my MX5. If anyone could offer some advice on what kind to get, maybe even approx. costs, that'd be a huge help. Thanks!
Vroommm.
- Matty
- Bevan
Bevan wrote:What year MX5 do you have? There's been quite a few second hand setups lately due to people upgrading to coilover suspension.![]()
I've got a Koni shock/Eibach spring setup and I couldn't be happier.
I've got an oldie, but great condition, 1989 MX5! The rides become very rough in the past months, and I'm going to do the back two first, then the front when my budget allows for it. So I'm not looking for anything terribly expensive, just enough to do the job well.
Vroommm.
Slugoid wrote:I have Koni shocks/King springs and I'm really happy with it. It's a really good budget setup without going to coilovers.
I have also heard KYB AGX shocks to be alright too, but don't take my word for it. They are cheaper than the Koni's, but not height adjustable. People say it's easier to adjust on the KYB's but I reckon it's just as easy with the Koni's.
Thank you! Can I ask a rough cost to give me an idea?
Vroommm.
- jules
- Guitar Hero
jules wrote:I would not do just the front or the back!
That could be a recipe for disaster.
I would rather buy the back set first and sit them under the bed until I could afford to get the front set as well.
Jules
How come that'd be a bad move to make?
Vroommm.
- jules
- Guitar Hero
- adamjp
I'm with Jules to some extent....
If I had to choose an end to do first, I would go the front...it is the end that stops you, steers you and carries most of the weight of the car. The other end just gets the power down - I will take loose power delivery over loose braking and steering any day.
I'm with Bevan
Thanks to Steve Tinker in QLD I got them at a steal too!
I'm with Bevan
Adam
- rodent
- 강남 스타일
While at Straight-Talk the other day Louie was going on about how much better the Aus-spec KYB AGX's are over the Konis. Something about having both dampening and rebound adjustments, as opposed to just dampening on the Konis.
Also, even the softest settings on Jap-spec shocks (be it Konis, KYBs, Teins or whatever) are apparently still too hard for Australian conditions.
All news to me, and (potential COW issues aside) very enlightening.
jonno.
jonno.
- Matty
Konis aren't Japanese
Many Jap shocks have had a reputation for being overly stiff. Fulcrum have Australian spec Teins that should be more suitable.
Compression damping adjustment is largely unnecessary as it is primarily a requirement of the vehicle weight, not of the springs. Not many people alter the weight in any significant way. Hence, rebound-only adjustment is usually fine.
- rodent
- 강남 스타일
Matty wrote:Konis aren't Japanese![]()
Haha I just realised that. He probably said "imported" or something...
Matty wrote:Compression damping adjustment is largely unnecessary as it is primarily a requirement of the vehicle weight, not of the springs. Not many people alter the weight in any significant way. Hence, rebound-only adjustment is usually fine.
Very interesting. I'm a suspension newb too so this is great info.
jonno.
- Mr_Q
rodent wrote:While at Straight-Talk the other day Louie was going on about how much better the Aus-spec KYB AGX's are over the Konis.
LOL - he must be getting a commission or something.
Mister Q
Had: Red 2004 SE, Red 1993 NA8 Clubman, Green 1991 NA6 LE
