Tyre pressures
- Brad
- RobbieRat
- jules
- Guitar Hero
Since we're revisiting this topic, as mentioned I run 33 front/34 rear.
I HATE understeer, and have assumed that with the slightly harder rear, it shoud make the car a bit more neutral leaning towards oversteer.
Suspension settings are the same all round.
Does this make sense to any of you propeller heads, or am I just having a toss thinking that I can feel 1psi, cause I can tell when the tyres are down by 2psi.
Jules
Jules
JBT wrote:Insurgence wrote:Can anyone tell me how much tyre pressures vary depending on hot/cold?
3-5 psi or more depending on what you're doing to them. BTW, I think 40 psi hot is far too high for the street.
ok i'll do a bit of experimentation. i'm not sure what is normal and what's not.
but maybe i can't really tell because my car has done >100,000 and it's still on stock suspension (i think)
i did notice more road noise when i got the new fronts put on, not sure if that is the new tyres or the high pressures
NB8A
JBT wrote:Try about 32 psi cold. That should be fine for street use IMHO.
Hey I finally got around to deflating my tyres.
whoa it feels so much better now! thanks
NB8A
- conchaae
- Vehicle: ND - 2
I run 36psi cold all round for the street and 38psi hot all round for the track.
For the street the psi doesn't come up all that much when hot and is a good balance between ride comfort & ride safety (No good having psi too low weak tyre walls = slower response time from rim to rubber). But if I am having a spirited drive, the psi comes up to \"track psi\" for that familiar feel. I've spent a lot of time learning about this matter and have heard from the best. In the end it's all personal choice hence why it always comes up as a good discussion topic.
That's my two cents and here's where I brag...see sig for current all time lap record for a standard NB8 at Wakefield.
Was just getting started, now in semi-retirement
Silver '01 NB8B Stock Standard Wakefield 117.83 ... 117.26 ... 116.95 ... 116.90
Users browsing this forum: No registered users and 194 guests
