King Springs & KYB shocks
gregord
Postby gregord » Tue May 02, 2006 8:33 pm
When I bought my 90 model I had to replace the existing springs and shocks. I took my car to a local suspension place and they installed king springs ( 1\" lower & firmer) and KYB shocks (non-adjustable).
Ever since there's been a very firm ride and constant banging as I go over bumps.
I've checked all bushes and ball joints and had another suspension \"expert\" do the same. He pointed out that there was only 3.5 cm from body of shocks to bump stops, but could find no other faults.
Is this the way things should be?
JSE
Postby JSE » Tue May 02, 2006 8:41 pm
Remember an MX5 is a sports car, not a luxurious cruiser...
Yes, it's perfectly fine as far as I know. I got my 89' stock standard and straight away put Bilstein non adjustable shocks and kings springs lowered 1 and 1/4 inches. I wanted to lower mine 2 inches but my suspension guy told me not to as the shcoks would actually \"bottom out\" if I went any lower. A much much much firmer ride and I find myself constantly dodging any little hole in the ground otherwise there is an almighty THUMP and then rattling.
To me it sounds exactly like mine...It is by far the hardest and firmest ride I have ever felt and owned.
Hope this helps in some way.
Garry
Postby Garry » Tue May 02, 2006 9:18 pm
I had the KYB non adjustable shocks on my car and found them way to soft. They had less control than the 80000km Mazda shocks I replaced. I doubt they would have any hope of controlling lower stiffer springs. I'm guessing you're probably riding on your bump stops. Strange as this may sound a stiffer shock may actually smooth out your ride by keeping the car off the bump stops. The KYB AGX adjustable shocks fixed the rough ride problems in my NA.
Mr_Q
Postby Mr_Q » Wed May 03, 2006 9:44 am
Also don't forget that unless you've added some, the 1990 cars have almost no bracing at all. My 1991 MX5 rattled a fair bit (on Konis and Kings) until I put the Mania chassis braces on - then it behaved a whole lot better. A cockpit brace of some sort (even a style bar) would probably help too.
Mister Q
Had: Red 2004 SE, Red 1993 NA8 Clubman, Green 1991 NA6 LE
Users browsing this forum: No registered users and 121 guests
