Mmmm... TEINie Goodness!
Fra66L
Postby Fra66L » Sat Apr 29, 2006 6:25 pm
Nope, no young girls here... :D
After 2 weeks up on chassis stands, The Green Meanie is back on it's feet complete with Teins (SS) new bushes (poly & OEM) and an NB TorSen.
<Insert shameless plug for Graham and Callum at Fulcrum Marooka - great guys>
Image Image
Still fiddling with the settings and bedding them in ready for QR on Tuesday but initial feelings are Gooood! The LSD makes tail-out moments way more fun and doable in the dry (if determined). :mrgreen: :mrgreen:
Yet to try it in the wet... :D
The Green Meanie - Grace Green NB8A
Veilside - It's Japanese for UGRY!
bigdog
King of the kennel
Postby bigdog » Sat Apr 29, 2006 7:15 pm
And thanks to the Tein Bug I fitted my Koni/King combination today - what an improvement! I love it! Thanks Fra66L and Dr Tein! :lol:
Matty
Postby Matty » Sat Apr 29, 2006 9:59 pm
Take some spanners to the track with you. You'll want them to unbolt the rear sway bar with.
Fra66L
Postby Fra66L » Sat Apr 29, 2006 11:04 pm
I know there's a good reason Matty..... :?:
Reduce over-steer?
Shouldn't hit the a-arms as it's sitting a little higher now than on the Konis/Kings...
T
Matty
Postby Matty » Sun Apr 30, 2006 4:28 pm
Fra66L wrote:I know there's a good reason Matty..... :?:
Reduce over-steer?
Correct. I assume you have the 7/6kg F/R spring rates? You'll want either a big front sway bar, and/or no rear bar, to balance it out. High speed oversteer is exciting to say the least...
Brad
Postby Brad » Sun Apr 30, 2006 11:00 pm
I found mine very neutral at the track. QR has several high speed turns, T1 and T2 midcorner I'm doing 135 and 120 respectivly. I did have mine set to 14/14 initially then went to 15/13 and it was very neutral and predictable.
maxwolfie
Postby maxwolfie » Sun Apr 30, 2006 11:06 pm
damn you and your tricks :P
'89 JDM NA6 (black)
2" s/s ex., 4-2-1 extractors, high flow cat, RX-7 AFM + pod, lightened fly, h/d clutch, 2 way lsd, slotted rtrs, Racing beat type II front bar, Speedy 17" wheels
CT
Postby CT » Mon May 01, 2006 2:04 pm
The SS's are pretty good Matty - not like our HA or Flexs - much more neutral. 8)
Philip Lee
Postby Philip Lee » Mon May 01, 2006 3:15 pm
Matty wrote:Correct. I assume you have the 7/6kg F/R spring rates?
they should be F6/R5.
Matty
Postby Matty » Mon May 01, 2006 5:57 pm
CT wrote:The SS's are pretty good Matty - not like our HA or Flexs - much more neutral. 8)
Spring rates:
HA: 5/4 = oversteer
SS: 6/5 = ?
Flex: 7/6 = oversteer
I find it difficult to believe that the SS's are steady-state neutral at the limit...
tk421
Postby tk421 » Mon May 01, 2006 7:05 pm
Nice Tone, imagine what the car will be like corner weighted with the butterfly brace on as well :roll: (the wait is getting a bit old aint it!!)
Steve
98 NB8A, Mania CAI, Eibachs and Bilsteins, Whiteline brace, Starcorp's, DBA Slotted and asstd bling, FM butterfly brace. FFS coldside and the whiiiinnne. Now 138rwkw (Glory Run :) ) More with tuning.
http://users.tpg.com.au/usethe4c/Green+Machine.jpg
Fra66L
Postby Fra66L » Tue May 02, 2006 10:12 am
TK,
Not wrong mate. I'll be in Sydney in a couple of weeks and I'm hoping they'll be ready to go so I can pick tehm up while I'm in town....
T
CT
Postby CT » Tue May 02, 2006 1:28 pm
Spring rates:
HA: 5/4 = oversteer
SS: 6/5 = ?
I thought that too before I bought them - but they are pretty good. Their damping is very nice and for some strange reason, they just work well on the NBs. I think they are the perfect setup on an NB, firm and well damped but not crashy at all. I really like what it's done to our road car. 8)
Fra66L
Postby Fra66L » Tue May 02, 2006 2:50 pm
Bear in mind also that these are the Aus-delivered (Fulcrumised) Tein SSs so they're not as firm as the Jap-spec model...
Didn't make the damn track day today after all (bugger it!) thanks to a nasty stomach bug. Have to wait until next month.
CT - been following the thread on sways - I believe the bars on the NB are slightly bigger but I'm curious as to how much of a difference they make on the NBs... thoughts?
SSs - Brings back memories of the SS Essess - too many Lloyd Briges movies
T
Philip Lee
Postby Philip Lee » Tue May 02, 2006 3:24 pm
The spring rate is the same whether it's jap spec or fulcurm spec, not sure if they have changed anything on the shocks tho.
