Squeel on takeoff - clutch bearing?
Insurgence
Postby Insurgence » Sat Apr 29, 2006 2:51 am
Hi,
I get a squeel if i take of at a reasonable speed off the line (ie launching in first gear).
it's only when the clutch is 1/2 engaged, and doesnt occur if i take off really slowly or when the clutch if fully out/in.
i had a search on the archives and sounds like the clutch bearing.
any get something similar? also what about $$ to fix? :mrgreen:
NB8A
JBT
Postby JBT » Sun Apr 30, 2006 7:00 pm
IMHO it's more likely to be the spigot bush - where the gearbox input shaft engages into the fly wheel. The bush should be replaced when the clutch is replaced.
SileNceR
Postby SileNceR » Sun Apr 30, 2006 7:12 pm
if it is the spigot bearing/bush (is it a bearing or a bush on the mx-5's?)
it should be under $10...
labour is where it gets expensive if you don't have the know how yourself...
Insurgence
Postby Insurgence » Tue May 02, 2006 3:56 am
hmm is it going to break anything if i take a while to change it? :?:
i'll see if i get get an opinion and maybe work out how to change it myself hehe
NB8A
SileNceR
Postby SileNceR » Tue May 02, 2006 7:33 pm
just get both and borrow a knowledgeable friend and make an afternoon of it... no point doing just the spigot and then having the thrust race start making noise a month later :D
Brad
Postby Brad » Tue May 02, 2006 10:51 pm
Mine does this too. I plan on changing whatever is needed when if have to do the clutch. What are the parts to replace if the clutch is out?
Clutch (duh)
Spigot bearing
Throwout bearing
Anything else?
SileNceR
Postby SileNceR » Tue May 02, 2006 11:05 pm
definately machine the flywheel -- no clutch warranty without it (and if you've been thinking of installing a light-weight flywheel, this would be the time!)
Brad
Postby Brad » Wed May 03, 2006 12:36 am
I don't think I'd go substantially lighter, perhaps a little while it's getting machined.
OMY005
Postby OMY005 » Wed May 03, 2006 8:49 am
Mine just started to squeal this morning as well. :(
Group buy on spigot bearings then. :)
Previously, White 95 NA 1.8 Hard Top,Stock standard
Now, 2016 Fiat 500x, 2014 Fiat 500, 2015 ND GT 2.0
Insurgence
Postby Insurgence » Sat Sep 30, 2006 7:33 pm
Almost 5 months on my car is still squeeling away (helps me practice not riding the clutch)
Dealer seems to think it's the thrust bearing on the transmission, and if that were the case it is ok until it gets really really loud.
has anyone fixed their squeeling with success? :mrgreen:
NB8A
CT
Postby CT » Sat Sep 30, 2006 7:51 pm
Bearing traders do them for $6 - bought one last week.
If you intend on changing flywheels, make sure you have brand new from mazda flywheel bolts - never use old flywheel bolts. Use loctite on the clutch ones as well. Plus, use the correct high temp grease on the throw out and pilot bearings as well as the fork pivot, contact point and the input shaft. 8)
Uncle Arthur
Dodgy Award Benefactor
Postby Uncle Arthur » Sat Sep 30, 2006 10:56 pm
Brad wrote:Mine does this too. I plan on changing whatever is needed when if have to do the clutch. What are the parts to replace if the clutch is out?
Clutch (duh)
Spigot bearing
Throwout bearing
Anything else?
Now if only you'd attended dodgy day.....
CT wrote:If you intend on changing flywheels, make sure you have brand new from mazda flywheel bolts - never use old flywheel bolts.
And other than asking 'why', this advice is also just over a week too late....... :|
CT
Postby CT » Sat Sep 30, 2006 11:29 pm
Bolt stretch. Flywheel bolts are very fine threaded bolts which are done up to from memory somewhere around 100nm of torque. This stretches the bolts. Once stretched, the strength factor is much reduced. New ones even come with the factory loctite material on them. For about ~$40 maybe, you'd have all new bolts.
Users browsing this forum: Google [Bot] and 5 guests
