Clutch, again =/
rodent
강남 스타일
Clutch, again =/
Postby rodent » Fri Apr 28, 2006 11:50 am
After a month or 2 of smooth running, my clutch is again having issues refusing to release properly, and this time it seems worse :|.
It sorta feels like a failed slave cylinder at first, but I find that pumping the clutch pedal actually helps - seems to me like it's just not building enough pressure or something. Fluid levels have remained on max, btw.
So before I take this down to my friendly mechanic, does the brains trust here have any ideas on what the problem could be..?
jonno.
maxwolfie
Postby maxwolfie » Fri Apr 28, 2006 12:20 pm
Not having much luck, are we? :?
Cant help you, just a useless rub-it-in post :)
'89 JDM NA6 (black)
2" s/s ex., 4-2-1 extractors, high flow cat, RX-7 AFM + pod, lightened fly, h/d clutch, 2 way lsd, slotted rtrs, Racing beat type II front bar, Speedy 17" wheels
Garry
Postby Garry » Fri Apr 28, 2006 12:52 pm
Try bleeding the clutch hydraulics of air.
rodent
강남 스타일
Postby rodent » Fri Apr 28, 2006 5:07 pm
Always a lifesaver Garry :D. Is air getting into the system something that just happens from time to time or should I be changing a part/clutch fluid to stop it happening in the future?
And I knew I could count on you to rub it in maxwolfie :P. My car ain't dodgy, it's got character.
jonno.
Craig
Postby Craig » Fri Apr 28, 2006 6:25 pm
rodent wrote:My car ain't dodgy, it's got character
More like it's dríven by a dodgy character! :lol: :P :lol:
Russellb
RIP Nov 2014
Postby Russellb » Fri Apr 28, 2006 8:12 pm
I know you said that the fluids are on the max but have you pulled the dust boot off the Slave Cylinder? If you find fluid in the dutst boot theres your problem . Sounds like the slave cylinder seal is letting Air inti the Hydrulic system. Bleeding the clutch may help the problem for a few weeks
Alf
Postby Alf » Fri Apr 28, 2006 9:47 pm
Russellb wrote:I know you said that the fluids are on the max but have you pulled the dust boot off the Slave Cylinder? If you find fluid in the dutst boot theres your problem . Sounds like the slave cylinder seal is letting Air inti the Hydrulic system. Bleeding the clutch may help the problem for a few weeks
I'm with brussell! Sounds like time for a slave cylinder kit. though perform his check to be sure, to be sure.
Garry
Postby Garry » Fri Apr 28, 2006 9:54 pm
But he only just had it replaced a few weeks ago :shock:
Craig
Postby Craig » Fri Apr 28, 2006 9:56 pm
Ahhh...replaced or did it just have a rebuild kit put through it? :?:
JBT
Postby JBT » Fri Apr 28, 2006 10:14 pm
It sounds like a hydraulic problem especially if pumping the pedal fixes it - slave or master cylinder.
Russellb
RIP Nov 2014
Postby Russellb » Fri Apr 28, 2006 10:20 pm
Might check the Clutch Master Cylinder too
Stick head under dash and have a look at the firewall near the clutch pedal and see if there is any fluid leaking (a fluid leak will eat/strip the paint away and it can run down under the carpet causing rust )
rodent
강남 스타일
Postby rodent » Sat Apr 29, 2006 12:26 am
Actually, the problem seemed to have cured itself the first time I experienced it a few months back, so I never got around to properly checking/replacing the slave cylinder. Looks like I'll be doing that now...
Unrequited love is a bitch, ain't it..? :P
jonno.
Garry
Postby Garry » Sat Apr 29, 2006 9:08 am
Get your hydraulics looked at Rodent, you have a leak in there somewhere.
Users browsing this forum: Google [Bot] and 5 guests
