Quads!
EGG80X
Quads!
Postby EGG80X » Tue Apr 25, 2006 12:17 am
So tempted to get a quad throttle bodies, anyone got them setup on their car?
once the fuel rails, ecu and throttle bodies are in place, is that it? doe it require mods like cams, pistons and stuff?
bigdog
King of the kennel
Postby bigdog » Tue Apr 25, 2006 1:58 pm
Thank god - I thought you and your partner were having a multiple birth! :mrgreen: :roll:
namster
Postby namster » Tue Apr 25, 2006 2:37 pm
RS AIZAWA!!!
zoom zoom zoom...
Craig
Re: Quads!
Postby Craig » Tue Apr 25, 2006 2:46 pm
EGG80X wrote:So tempted to get a quad throttle bodies, anyone got them setup on their car?
Firstly they're illegal and yes you really need to mod the engine to run them. Save your $$$ for a turbo kit instead or just upgrade to an NB8B for less $$$ :P
Alf
Re: Quads!
Postby Alf » Tue Apr 25, 2006 9:33 pm
A few weekends spent tuning a Honda S600 or S800 should cure you of that!
Honestly, why not add drum brakes all round and a column shift while you're at it.
Alf
SuperMazdaKart
Postby SuperMazdaKart » Wed Apr 26, 2006 12:14 am
would using dual carbs like webbers or motorcycle carbs be almost the same thing & cheaper?
glen73
Re: Quads!
Postby glen73 » Wed May 03, 2006 1:37 pm
yer mate it doesnt stop there, if you want real power then alot of internal has to be done. i wouldnt bother with a nb8b engine unless your going to turbo it as a standard nb8b doesnt really compare to a turboed 1.6. :lol:
i know they use the AE101 throttle bodies in jap racing from a toyota
heres a little vid http://www.yourfilelink.com/get.php?fid=95618 38 meg where you will see some nice setups. this is more for the younger guys
CT
Postby CT » Thu May 04, 2006 11:16 am
Guys, having just fitted quads to my race car, I can assure you that they aren't that much harder to tune if you get your shafts synchronised properly during assembly Depending on which quads you use this can be easy or hard. Mine were simple. The throttle response is simply amazing. And as for rewiring, it's only changing the 4 wire TPS to a 3 wire TPS like a delco - about a 15 minute job. Even if you move the injectors into the runners, the standard loom is long enough so it's not that hard. 8)
Matty
Postby Matty » Thu May 04, 2006 11:59 am
CT, what load sensing method do you use?
Andrew
Postby Andrew » Thu May 04, 2006 12:20 pm
Something like this would be nice -
CT
Postby CT » Thu May 04, 2006 12:29 pm
Matty wrote:CT, what load sensing method do you use?
None - all on throttle position - no MAP at all. I have always questioned it but all the tuners who have tuned my car reckon it's the way to go with NA race engines. So far they seem to be pretty right. 8)
adamjp
Postby adamjp » Thu May 04, 2006 8:47 pm
No. It wouldn't be 'nice'.
It would be FARKIN AWESOME!
Adam
Curly
Postby Curly » Thu May 04, 2006 10:26 pm
Andrew wrote:Something like this would be nice -
All of a sudden my pants are too tight. :)
glen73
Postby glen73 » Thu May 04, 2006 10:29 pm
they should loosen up once your wallet becomes empty
