THE REAL BORIS wrote:is anyone out there using the XEDE and to what effect?
I think there are better solutions than the Xede out there.
THE REAL BORIS wrote:The main attraction for me is the new plug-in loom and facility to switch between MAPS, meaning power when you want it and standard when you don't. Modified hardware will simply not pass inspection getting overseas.
ASE05 wrote:It's definately not a necessity but having a having a couple of maps is handy:
Wet weather - always nice to be able to dumb it down in a car that struggles for traction in the dry(my previous Skyline was one)
I'd like to think no-one can give the car more abuse than I doASE05 wrote:Lending your car out - sure not many of us would allow someone we didn't trust to borrow 'em for a while but in the event someone unfamiliar has to get behind the wheel it's good insurance.
ASE05 wrote:Dodgy fuels: no reason you can't have two maps, one for 98 and the other for 91. Handy once your outta the burbs stuck with regular unleaded or diesel as your only fuel options!
THE REAL BORIS wrote:An opinion only,
The MAIN reason for at least two maps being useful (for me) ...........
The Mazdaspeed Forum in the States have had plenty of feed-back on their website over the last 12 months regarding the XEDE.
Vishnu performance kits (sub-zero and zero) use the XEDE's tuning ability to muster up another 25/50 rwhp. The only hardware changes are an alternative bov in the sub-zero and dual spray injectors and new air intake in the zero. Unfortunately, as with all things new, some tings come to light with the passing of time, namely low speed driveabilty issues were encountered by some of the users. Typically, driving in slow moving traffic, car parks etc. Any way, two maps would have fixed the problem, especially with the switch between the two being at your fingertips (on the run). Chiptorque apparently fixed all this pretty smartly by going to the States no less. Now there are some people on the Mazdaspeed Forum (with the single MAP) saying that they have lost rwhp. The early systems were hard wired into the loom and only one map was used. The new version, with the Vishnu plug-in loom (great for removal when I need to get it back to stock for export) is the way for me. Could be stage sub-zero was at the limits or, being smoother now, the owners pants are not being jerked about so much, whatever. I think it is a good product and the sub-zero is for me since the extra 25 rwp of the second version has hardware in your face (the intake system) and the extra poke is only over the last 1000 rpm. More for competition than street I feel.
Finally, Chiptorque are here in Australia (almost next door), and the so called sub-zero is just the XEDE after all, plus some VERY IMPORTANT tuning expertise to get it to work.
ASE05, would you rather I stayed away on 10.04.06, my car is ready for the work too? I would like to compare the Dyno numbers.
THE REAL BORIS wrote:Unfortunately, as with all things new, some tings come to light with the passing of time, namely low speed driveabilty issues were encountered by some of the users.
ASE05 wrote:SP are only using a 2.5" system to avoid the boost cut and whilst their initial figures were definately optimistic for just the upgrade kit, it sounds like 150 + rwkw shouldn't be a problem with the use of a piggy 'puter. The figures themselves aren't that important to me, it's the percentage of increase that I'm looking for.
Sean wrote:ASE05 wrote:SP are only using a 2.5" system to avoid the boost cut and whilst their initial figures were definately optimistic for just the upgrade kit, it sounds like 150 + rwkw shouldn't be a problem with the use of a piggy 'puter. The figures themselves aren't that important to me, it's the percentage of increase that I'm looking for.
Good luck mate, sounds like a realistic goal and the right attitude![]()
If it doesn't make teh power, just add some more boost
THE REAL BORIS wrote:low speed driveability in a tune has nothing to do with peak hp ability.
Sorry Sean, I don't understand what you are trying to convey.
THE REAL BORIS wrote:So, if I understand you correctly, if Chiptorque and Vishnu etc. claim more horsepower from a standard factory car by changing the engine management parameters and not any hardware, the factory could have done a better job, since both cannot be as good as each other?
I cannot agree with that; they are just different. The factory is more conservative on boost, timing etc. presumeably for longevity. But, the aftermarket guys get more power at the expense of something surely. So, why not have both?
As far as the factory offering more than one program, how are they going to have a base for warranty? All their cars are a compromise of some sort, to fit into a market niche.
The only place I can think of where there is little room for compromise (and cost is the least of their worries) is Formula One; how many choices do they have from the drivers' seats I wonder ...... ? IF it is more than one, then why?
