Style Bars - More installation tips
jules
Guitar Hero
Postby jules » Tue Apr 04, 2006 9:44 am
Hey!
Mine just arrived at the depot. Cool. Time to play.
Now, are we sure the captive bolt is an M10, not a UNC or 3/8 thread??
Jules
JBT
Postby JBT » Tue Apr 04, 2006 3:06 pm
jules wrote:Now, are we sure the captive bolt is an M10, not a UNC or 3/8 thread??
Mine and Richee's were M10
jules
Guitar Hero
Postby jules » Tue Apr 04, 2006 3:10 pm
Cool, got the style bar and the extra long M10 nuts.
They sold me manifold nuts if anyone has trouble getting a long nut, ask for that :shock: :shock: :shock:
Jules
Amanda
Postby Amanda » Thu Apr 06, 2006 1:55 pm
HOw many of you have changed the actual seat belt bolt like npn did back on page 2 of this thread? That bothers me, will we have to do that? Or can we just cut the seatbelt plastic cap thing that sits on it?
jules
Guitar Hero
Postby jules » Thu Apr 06, 2006 1:59 pm
With my NA, I have had to do neither. I've used the bling spacer, original bolt and plastic cap unaltered.
Jules
jules
Guitar Hero
Postby jules » Thu Apr 06, 2006 2:16 pm
One question I do have is does anyone who has fitted one of these find the top of the hoops rest against the soft top/zipper?
Jules
JBT
Postby JBT » Thu Apr 06, 2006 2:57 pm
Amanda - I used the original bolt and original top spacer.
Jules - my (new) roof juuuuuust clears it but flaps against it once the speed goes above about 60Km/hr. Another good reason for driving topless only :)
jules
Guitar Hero
Postby jules » Thu Apr 06, 2006 3:10 pm
That sounds pretty annoying??
Mine could do with a 10mm drop, to get some decent clearance. It's into the soft top about 2mm.
I can live with it, as there's no way I'm taking a grinder to the seatbelt tower box.
Jules
Bevan
Postby Bevan » Thu Apr 06, 2006 3:16 pm
jules wrote:That sounds pretty annoying??
2mm?! How high do these things go? And quite a long way back by the sounds of it. :?
jules
Guitar Hero
Postby jules » Thu Apr 06, 2006 4:03 pm
On an NA they go back as far as the zipper and as high as it as well. Keep in mind the soft top is quite low in that spot.
They clear your head, that's my main interest.
Jules
ma64rk
Postby ma64rk » Fri Apr 07, 2006 11:49 am
Amanda
I didn't change seatbelt bolt, i just trimmed plastic cap...
Jules, i took mine out after first try at installation, removed a few spacers, and dropped it by about 15mm...and replaced it...much better clearance on soft and hard top!
Take the road less traveled...
Silver 01 w/hardtop & stylebars...
jules
Guitar Hero
Postby jules » Tue Apr 18, 2006 11:01 am
15mm!!!
How many spacers did you have on there?
Jules
ma64rk
Postby ma64rk » Tue Apr 18, 2006 10:25 pm
Umm...ahhh.a few too many :oops: What I did was install it on the friday nite the package arrived, without getting all of the bits I needed and taking my time...I was just too damned excited! Anyways, I used spacers I already had...suffice to say, second time i went out and got exactly what was needed. It clears both hard/soft top easily now, no prob's.
adfox
Postby adfox » Sat Apr 22, 2006 12:03 pm
For those having trouble with roof clearance with the bars, the instructions have a few paragraphs on adjusting the roof so it sits higher, if I understand it correctly. Ours just cleared the bar thankfully.
Adam
JBT
Postby JBT » Sun May 07, 2006 10:01 pm
Update. I fitted one of these bars to a friend's NB8A today.
Roof Clearance. The top part of the roof window rubber surround rests on the bar when the roof is erected. We tried adjusting the roof height but it only moves a very small amount - the window rubber still sits against the bar. :frown:
Seat belt shoulder point. I compared the NB bolt with the NA bolt and blow me down if the NA bolt isn't about 15mm longer. :) Just what the doctor ordered. So all that trouble Mike (npn4875) went to getting longer bolts and making shoulder sleeves wasn't necessary. :roll: Also the NA plastic caps fit on the NB harness swivels and have far less overhang thus less interference with the bar.
BTW, this bar came from WA and the passenger side hoop is also slightly higher than the driver side :?
Users browsing this forum: No registered users and 18 guests
