Spray paint or powder coat the wheels?
- pcmx5
- Vehicle: ND - 2
- Red Baron
I have a set of rims that were 2 packed in white, use them for track with DO1's, they get heavy brake dust and all the other crap off the track.
A little Meguiars and they come up beautifully.
Powdercoating while durable is also brittle, so I think it would be prone to chip on a wheel, where 2 pack has not.
My experience
baron
My experience
baron
Red
True Red NC Touring, Tein's, sways, beatrush chassis suite, roadstersports exhaust, starting to steer like a sports car, and stop like a bee with Hawk pads and DBA4000's! And still the wife's shopping cart, "Gold"
- adamjp
I just refinished some wheels using the new Holts Duplicolour wheel paint.
http://www.duplicolor.com/projects/howto_wheel.html
You cannot get the damn clear in this country yet.
The big lesson that I re-learnt is that you need to strip the old paint/primer/filler off the wheels in order to have it look good. I didn't quite get it all off and they look like crap up close. Still, it was a learning experience, and I learnt.
No idea how the duplicolour will age, but since it is a polyurethane, it should be as tough as hell. It went on over etch primer, so it ain't coming off anytime soon.
Adam
ncmx5 wrote:well, i would like a gun metal grey against a red car. im still not sure.
Like mine?:
- adamjp
The paint is about $16 a can. 2 cans will be enough for 4 rims. Etch primer is around $15 and one can is enough.
The key is to get the old paint, etc. off. Try a bead blaster or professional paint stripper.
Adam
- green_comet
- Car Detailing Guru
adamjp wrote:I just refinished some wheels using the new Holts Duplicolour wheel paint.
Where abouts did/can you buy this paint from?
I am looking for an inexpensive way to clean up my rims!
Phew, just completed doing my set of rims. I have used the 'Dupli-colour' High Performace Wheel Coating (Graphite) for mine. One spray can will do the job (3 coats) but I had another can to make it four coats. I then put 2 coats of clear over the top.
The worst part is using the paint stripper and making sure it's nice and clean.
Thanks goes to 'adamjp' for his help in sourcing this product.
Before
After Paint Stripper
Final product (Excuse the overspray - I have a new set of tyres to put on
Products i used in order
Before
