I didnt get a hat tho
JBT wrote:Looks like a really great set up Brad
Questions:
1. Where is the shock rate adjustment? On top?
2. Please explain how the ride height can be adjusted yet still retain full shock travel. I can see that the perch is adjustable and I guess the lower ring is a lock ring. But I cannot get my head around how lowering the perch still leaves full shock travel.
Fra66L wrote:The stray bolts don't tend to run too far when you drop them either...![]()
Brad wrote:JBT wrote:Looks like a really great set up Brad
Questions:
1. Adjustment is on the top, under the little rubber boot.
2. SS's can only change spring perch height, therefore the lower you go the less travel you have. The Tein Flex allow seperate adjustment though http://www.tein.com/flexdamp.html
I understand though that at factory setting they have similar travel to standard, though not positive. I'll take pics of the install and have them up next week.
JBT wrote:Thanks for the replies Brad and Juffa. I get it now. Need the Flex for height adjustment and full travel. Suppose they cost a lot more than the SS?
Cal wrote:As an alterative, got a price on the AVO coils today = $283ea.
Cal.
Brad wrote:I decided to leave the heights at what they came out of the box as a point of reference. Originally the car sat a 345 at the front and 340 at the rear. It's now down to 330 at the front and 335 at the rear after a few hours of settle. To me the rear is sitting about 2cms too high and the rear about 1, though I'll wait a bity to see if they settle any more.
Brad wrote:Once they were installed I counted the clicks from full hard to full soft on each corner and found the rears had 25(L) and 26(R) clicks, with the fronts both having 28. This has confused me somewhat as I don't know whether there are only 16 levels, with the extra clicks being at either extremity, or at both, rendering the first 4-5 clicks at boths ends useless, or as the case may be, that there are in fact that many levels of adjustment.![]()
