stock dyno sheets
muzza2
stock dyno sheets
Postby muzza2 » Wed Mar 22, 2006 7:50 pm
does anyone have a stock dyno sheet for an NA6
and i mean stock, no zorst, pod ect.
RobbieRat
Postby RobbieRat » Wed Mar 22, 2006 8:15 pm
Yep somewhere, she made a whole 58kw at the Dynoday@ Caulfield Jag.
SuperMazdaKart
Postby SuperMazdaKart » Wed Mar 22, 2006 8:19 pm
heres mine.
stocker at the time & with a busted O2 sensor.
rodent
강남 스타일
Postby rodent » Wed Mar 22, 2006 9:22 pm
65rwkw stock? Wow.
Did you bump the timing? Change the plugs or leads?
jonno.
edit: Ah it would have been running rich. Nm :?
SuperMazdaKart
Postby SuperMazdaKart » Wed Mar 22, 2006 9:28 pm
errr, i was under the impression 65 rwkw is the norm for a 1.6.. i don't know if the previous owner bumped the timing or not, but for the dyno it was on BP Ultimate 98 octane. had a buckled rear wheel at the time too :|
muzza2
Postby muzza2 » Wed Mar 22, 2006 10:38 pm
thanks for that =)
and does anyone know optimal gear shift change? somewhere up around the 7's i assume????
lol and dont say rev. limiter :P
rodent
강남 스타일
Postby rodent » Wed Mar 22, 2006 10:41 pm
Don't worry I'm being the newb as usual but I myself was under the impression norm was more like 55-60. 65 being the high end if you're lucky.
Looks like you are. Congrats =)
jonno.
Sean
Postby Sean » Wed Mar 22, 2006 10:47 pm
`Zoombie wrote:errr, i was under the impression 65 rwkw is the norm for a 1.6.. i don't know if the previous owner bumped the timing or not, but for the dyno it was on BP Ultimate 98 octane. had a buckled rear wheel at the time too :|
Mine must be down on power, only made 64.1 with zorst and Lochie intake.
And made about 59 when dead stock... (note dyno sheet is HP, translate to 59kw.)
rodent
강남 스타일
Postby rodent » Thu Mar 23, 2006 3:27 pm
V-Spec wrote:I made 87.4Hp on the exhaust shop dyno in Brendale a couple weekends back. Dyno chart looks exactly the same as Zoombie's only mine had km/h on the bottom.
Had a pod filter stuck on the afm right next to the stinking hot heat sheild as well. My first run made 87.1 and the next two were both 87.4 which shows a bit of consistency.
So about 65kW too. But isn't your BRG a 1.8?
jonno.
Matty
Postby Matty » Thu Mar 23, 2006 4:14 pm
muzza2 wrote:thanks for that =)
Revlimiter ;)
For 1,2,3.
Above that, maybe ~7000 rpm for 4th and 6800 for 5th.
and keep in mind that the tacho is optimistic, so you should pretty much always shift above 7...
Unmodified 1.6s make ~55-58kW at Caulfield Jag, and run obscenely rich.
Up to ~65kW with minor mods.
Variations on other dynos are due to calibration.
Sean
Postby Sean » Thu Mar 23, 2006 7:45 pm
Matty wrote:Unmodified 1.6s make ~55-58kW at Caulfield Jag, and run obscenely rich.
That's a bit broad Matty, there are plenty of things that will effect your Dyno reading besides it's calibration...
Tyre pressure, condition of engine, ambiant temp, engine temp and a million other things, hell even the amount of pressure they strap the car onto the dyno with will effect it's output.
Matty
Postby Matty » Fri Mar 24, 2006 8:30 am
Sure, but calibration should account for things like air temp etc to some degree.
My point was, a car that gets 55kW on one dyno may have just as much power as another car that gets 65kW on a different dyno...
Sean
Postby Sean » Sat Mar 25, 2006 4:26 pm
Matty wrote:My point was, a car that gets 55kW on one dyno may have just as much power as another car that gets 65kW on a different dyno...
Exactly. Back to back runs is the only way to compare dyno sheets.
irwin83r
Postby irwin83r » Sun Mar 26, 2006 12:05 am
which is why we should have a club dyno day. direct comparisons between different setups :D
JSE
Postby JSE » Thu Mar 30, 2006 4:17 pm
Noob question...you can run the dyno fully stock can't you...I mean you don't need a new computer/ecu...because I remember that my old man wanted to run his modified Type R on the dyno but they said he needed a new computer to do so...is this because of FWD or Vtec or the fact that Honda's run off little mechanics and lots of computers haha???
