stock dyno sheets
stock dyno sheets
does anyone have a stock dyno sheet for an NA6
and i mean stock, no zorst, pod ect.
- RobbieRat
- SuperMazdaKart
- SuperMazdaKart
- Sean
`Zoombie wrote:errr, i was under the impression 65 rwkw is the norm for a 1.6.. i don't know if the previous owner bumped the timing or not, but for the dyno it was on BP Ultimate 98 octane. had a buckled rear wheel at the time too
Mine must be down on power, only made 64.1 with zorst and Lochie intake.
And made about 59 when dead stock... (note dyno sheet is HP, translate to 59kw.)
- rodent
- 강남 스타일
V-Spec wrote:I made 87.4Hp on the exhaust shop dyno in Brendale a couple weekends back. Dyno chart looks exactly the same as Zoombie's only mine had km/h on the bottom.
Had a pod filter stuck on the afm right next to the stinking hot heat sheild as well. My first run made 87.1 and the next two were both 87.4 which shows a bit of consistency.
So about 65kW too. But isn't your BRG a 1.8?
jonno.
- Matty
muzza2 wrote:thanks for that =)
and does anyone know optimal gear shift change? somewhere up around the 7's i assume????
lol and dont say rev. limiter
Revlimiter ;)
For 1,2,3.
Above that, maybe ~7000 rpm for 4th and 6800 for 5th.
and keep in mind that the tacho is optimistic, so you should pretty much always shift above 7...
Unmodified 1.6s make ~55-58kW at Caulfield Jag, and run obscenely rich.
Up to ~65kW with minor mods.
Variations on other dynos are due to calibration.
- Sean
Matty wrote:Unmodified 1.6s make ~55-58kW at Caulfield Jag, and run obscenely rich.
That's a bit broad Matty, there are plenty of things that will effect your Dyno reading besides it's calibration...
Tyre pressure, condition of engine, ambiant temp, engine temp and a million other things, hell even the amount of pressure they strap the car onto the dyno with will effect it's output.
- Matty
Sean wrote:Matty wrote:Unmodified 1.6s make ~55-58kW at Caulfield Jag, and run obscenely rich.
Sure, but calibration should account for things like air temp etc to some degree.
My point was, a car that gets 55kW on one dyno may have just as much power as another car that gets 65kW on a different dyno...
- Sean
Matty wrote:My point was, a car that gets 55kW on one dyno may have just as much power as another car that gets 65kW on a different dyno...
Exactly. Back to back runs is the only way to compare dyno sheets.
- irwin83r
- JSE
Noob question...you can run the dyno fully stock can't you...I mean you don't need a new computer/ecu...because I remember that my old man wanted to run his modified Type R on the dyno but they said he needed a new computer to do so...is this because of FWD or Vtec or the fact that Honda's run off little mechanics and lots of computers haha???
