pull off ignition leads (only at the pug end, not at the coil or you'll forget which one goes where)
with 5/8\" spark plug socket on an extension, unscrew old plug and remove.
Grab new NGKs, insert into socket. insert socket into well.
Turn backwards (anticlockwise) until you hear it click. Then screw in finger tight.
Tension a further 1/4-2/3 of a turn (IIRC) with the socket handle. (it's written on the box)
Optionally you can put a dab of antisieze on the threads, but be careful not to get it on the electrodes.
Reconnect leads.
How to change Spark plugs?
- Matty
- CT
- ducktape69
- rodent
- 강남 스타일
- jules
- Guitar Hero
- rodent
- 강남 스타일
ralphie wrote:so until it clicks then add 1/4-2/3 of a turn??
cheers
It doesn't "click" as such - just turn it till you get some nice solid resistance, then tighten to spec as it says on the box.
You'll know what I mean when you try it
jonno.
