Pinoeer Head unit and Aerial....
- ducktape69
hey guys and gals....finally had my pioneer mp3 unit installed in the car and WOW what a difference from the standard deck....
my only gripe is that the aerial is always up when the unit is turned on...even when a cd is in there and NOT the radio....the installer told me all pioneer and sony units are like this....
any advice?
any advice?
BLECK 2002 Mazda MX5 NB8B. Custom Heatshielded CAI . KYB AGX's + King Springs. 17\" Bleck Rims. Custom BASSSS Install.
- maxwolfie
- ducktape69
after a bit of searching, apparently my pioneer is built that way...
so andrew if u coulf do do a quick write up or somethin of how u did it would be much much appreciated
a top nootch installer done it for me that ive dealt with and trust before...
he charges $60 for any headunit install....he even tracked down a 1 din slot/case from mazda to fill the hole left by the stock deck....
- ducktape69
- ducktape69
ive had a quick look at the jaycar website and d=fund this switch/button and wiring...are these suitable andrew?
http://www.jaycar.com.au/productView.asp?ID=WH3080&CATID=22&keywords=&SPECIAL=&form=CAT&ProdCodeOnly=&Keyword1=&Keyword2=&pageNumber=&priceMin=&priceMax=&SUBCATID=491
http://www.jaycar.com.au/productView.asp?ID=SP0700&CATID=28&keywords=&SPECIAL=&form=CAT&ProdCodeOnly=&Keyword1=&Keyword2=&pageNumber=&priceMin=&priceMax=&SUBCATID=652[/url]
- Andrew
Blue wire from the head unit i think. (check that with your installation manual)
Wire....not to sure what i used, doesnt need to me anything special as its only interupting a singnal.
Switch, here is the pic -
from left to right - dimmer, aerial switch and alarm LED.
- green_comet
- Car Detailing Guru
- ducktape69
thanks andrew. i cant put my switch there cause i have a nb8b therefore my fog lights switch is there...but i get the idea....
all im unsure about is where the wiring need to go from? headunit or from the car's loom/wiring? i.e. will this switch be sending a signal to the headunit or to the car(antenna) ?
and should i just straight cut the blue wire? or splice into the existing connection and add the new wire?
- ducktape69
sorry im confused....
my existting aerial connection is like this:
HEADUNIT----------=-----------CAR's wiring
should i just CUT this connection so it looks like this:?
HEADUNIT---------- --------CAR WIRING
and then connect the new switch like this:?
HEADUNIT-----------=-----------NEW SWITCH ???
OR should i leave the exisitn connection and splice the wire with the new switch so it looks like:
HEADUNIT
+-----------CAR WIRING
NEW SWITCH
HEADUNIT
NEW SWITCH
- Andrew
From google - A switch is a device for making or breaking an electric circuit.
all the switch is doing it stopping the signal from getting to the aerial ie: breaking the circuit, which inturn stops it going up and down.
My aerail stays down all the time, when i chooses to turn the radio on i have to press the switch to 'make' the circuit then the aerial will go up.
Users browsing this forum: Google [Bot] and 1 guest
