wil 17x8 +35 os fit???
lowmx
Postby lowmx » Fri Mar 17, 2006 5:18 pm
hi
will 17x8 with a plus 35 offset fit a na6? maybe require small amount of rolling of the guards??
Thanks
lowmx
Postby lowmx » Sun Mar 19, 2006 1:18 pm
can anyone help? wat offset will fit if its a 8inch wide rim? ill be running 205/40/17 rubber... anyone? :frown:
Babalouie
godfather of saké
Postby Babalouie » Sun Mar 19, 2006 2:57 pm
I think with that offset it will be ok with guard rolling. 8in with +35 offset is about the same as 7in with +22 offset, which is doable, but only with guard rolling. But that's just the outside clearance. Not sure about whether there would be enough room on the inside, given that it's 8in wide. I think it would be ok though.
So I think the offset is probably ok, I'm just not sure about the rolling diameter...I think a 205/40-17 is probably quite a bit bigger in diameter than stock and that's probably the thing that will cause issues if anything.
What's the difference in outside diameter between a 205/40-17 and a 185/60-14?
Dubly
Postby Dubly » Sun Mar 19, 2006 6:52 pm
185/60/14's are 22.7\"
205/40/17's are 23.5\"
205's are not wide enough to really take advantage of 8\" wheels. If you're going to go to all the trouble of fitting 17x8's on to a NA, I would strongly suggest you get some fender flares and wide tyres.
17x8 would be okay on a high-power race MX5 with big brakes.However, with stock power and brakes it would make your car slower and it would ride like crap.
What's you plan?
Users browsing this forum: No registered users and 195 guests
