NA6 Air Con removal
kula
NA6 Air Con removal
Postby kula » Wed Mar 15, 2006 10:46 pm
heya,
i pulled out my air con and it feels better..
i did however leave the brack that the compressor bolts to...
i have read on the big forum that one of the bolts is critical to the oil pump.
does anyone know which one?
It seems there are 3-4 going into the engine, and one longer one inline with the block holding the bracket to it.
lightweight rules:)
StanTheMan
OMG
Postby StanTheMan » Wed Mar 15, 2006 10:55 pm
really. :shock:
Im sure I had mine off completely when changing the engine. Nothing rattles now thankfully
StanTheMan
Re: NA6 Air Con removal
Postby StanTheMan » Wed Mar 15, 2006 10:56 pm
kula wrote:lightweight rules:)
You & slammer would make a great pair :lol: :lol: :lol:
kula
Postby kula » Wed Mar 15, 2006 11:21 pm
i need to go on a diet:P
Astroboysoup
Postby Astroboysoup » Wed Mar 15, 2006 11:42 pm
how do you deal with the heat on hot days without air con?
AustCars.net - It's like Facebook but for cars!
StanTheMan
Postby StanTheMan » Wed Mar 15, 2006 11:49 pm
he sweats it out.....& looses some weight in the process bawahahahaha :lol: :lol: :lol:
err sorry kula.....couln't resist.
there is no excess weight on kula :mrgreen:
errr back on track
how does the bolt connect to the oilpump internally ?
The Pupat
Postby The Pupat » Thu Mar 16, 2006 12:07 am
Astroboysoup wrote:how do you deal with the heat on hot days without air con?
I had my aircon disconnected for a couple of months over summer and the car felt faster. But I succombed and but a new compressor put in and all repaired. Best 900 dollars I've ever spent, I love Air Con.
'92, Red, Hardtop, Noisy CAI, Even more Noisy Exhaust, AVO Shocks with TJR Springs (Not so Fuli drifto speco).
Boyracer
MX-5 Encyclopedia
Postby Boyracer » Thu Mar 16, 2006 7:33 am
I think there are 4 bolts that hold the bracket from the side and there is a smaller bolt that come in from the front,that is the one that you need to replace,without the bracket it is too long so you need to get the shorter bolt.
sabretooth
Postby sabretooth » Thu Mar 16, 2006 8:30 am
I don't know which is critical to the pump, but why not try and see? If it leaks, then you've plugged the wrong hole. :)
And there's no way I'd remove my aircon. In hot weather it's bliss.
kula
Postby kula » Thu Mar 16, 2006 8:58 am
yeah its only a pain about 5-10 days a year...
worth it in my books..
yeah i finally found some more info on the big forum,
and lou is right, u need to replace the long bolt with a shorter one....
OMY005
Postby OMY005 » Thu Mar 16, 2006 10:12 am
sabretooth wrote:And there's no way I'd remove my aircon. In hot weather it's bliss.
Here Here :)
I was reading some posts from UK 5 owners and they are complaining there heaters are not hot enough. :shock:
Previously, White 95 NA 1.8 Hard Top,Stock standard
Now, 2016 Fiat 500x, 2014 Fiat 500, 2015 ND GT 2.0
4sfed5
Vehicle: NA6 - Turbo
Postby 4sfed5 » Thu Mar 16, 2006 2:29 pm
The bolt that needs to be replaced is the one that bolts to the "front" of the block, you can see it if you look front on at the engine between the power steering belt.
it clamps the oil pump to the block. if you dont replace it, you'll get a leak.
you have to get a new bolt as the old one is too long without the a/c bracket and cant be re used.
Zimma
Postby Zimma » Thu Mar 16, 2006 6:12 pm
Just outta curiosity... wanna sell your air-con now its outta the car?? :shock:
ZIMMA
That's what the plates say!
AJ
Postby AJ » Thu Mar 16, 2006 6:48 pm
Here Here :)
a POM???.....Whinging????........NOOOOOOOO...............surely you jest :roll: :lol: :lol: :lol:
XMX5 Rogues
sabretooth
Postby sabretooth » Thu Mar 16, 2006 7:54 pm
4sfed5 wrote:The bolt that needs to be replaced is the one that bolts to the "front" of the block, you can see it if you look front on at the engine between the power steering belt.
No bolts in the RHS of my oil pump. Is there something someone's not telling me? :)
Got a pic?
Users browsing this forum: No registered users and 39 guests
