Annoying squeak coming from the drivers side rear area
PT
Postby PT » Fri Mar 03, 2006 2:09 pm
Erwino wrote:any suggestions about my problem with the rooted alan key head that i cant seem to tighten?
We told you, that can't be tightened, they are welded in at the back.
Past:
2005 Mazda MX-5 SE
1991 Mazda MX-5 NA6
Bevan
Postby Bevan » Fri Mar 03, 2006 2:12 pm
Garry wrote:I used some fishing line wrapped around the pivot pin to tighten up the joints in my car. It works great, though its a bit of a bitch to get the fishing line into the joint.
rain902
Postby rain902 » Sat Mar 04, 2006 3:02 pm
Erwino wrote:i think we are talking about 2 different things.
because what im talking about is clearly not welded in at the back, but rather a normal screw with a washer around it, all the other screws are fine its just this 1 perticular screw seems like its been tightened too many times, because now the head is stuffed and the alan key just spins around in circles in the screw head.
gert an "easyout"
drill a hole into the thread, and screw the easyout into it - it has a reversing thread and the further you screw it in, it will bite and remove the screw. it takes a bit of care but once the screw is removed yu can fit another screw without a stuffed allen head and tighten it properly!
2013 Australian hillclimb champion 2F
2013 qld hillclimb champion 2F
Qld & Aus 2F state record holder-mt cotton
2014 vic hillclimb champion - 2A
JBT
Postby JBT » Mon Mar 06, 2006 10:48 pm
Try Bolts & Industrial Supplies, 145 Evans Rd Salisbury, Tel 3277 6944.
PT
Postby PT » Tue Mar 14, 2006 7:46 pm
IS this squeak something I could take to Mazda and have them fix it under warranty?
Past:
2005 Mazda MX-5 SE
1991 Mazda MX-5 NA6
AJ
Postby AJ » Tue Mar 14, 2006 8:36 pm
of course it is.
XMX5 Rogues
JBT
Postby JBT » Wed Mar 15, 2006 12:45 pm
My car developed a squeak after the new roof was fitted. It's taken me a few days but I finally found it :roll: . It was a rivet attaching part of the roof vinyl near a side frame that is upright when the roof is on/up. I thought it was some or one of the hinges. Anyhow, the rivet was juuuuuust touching the frame upright and making a hellava racket. It was way down near the catch trough for the rain rail. Moved the rivet one poofteenth of a millimeter and silence :) .
PT
Postby PT » Wed Mar 15, 2006 12:51 pm
That sounds like mine...
Mine does it when up or down though, certainly sounds like it's coming from the right direction.
Past:
2005 Mazda MX-5 SE
1991 Mazda MX-5 NA6
JBT
Postby JBT » Wed Mar 15, 2006 1:42 pm
I'll be at GP Cars tonight if you want to see where the problem was on my car.
PT
Postby PT » Wed Mar 15, 2006 3:02 pm
I'll be there.... I'll bring the MX5 too.
Past:
2005 Mazda MX-5 SE
1991 Mazda MX-5 NA6
PT
Postby PT » Thu Apr 06, 2006 9:00 pm
Ok guys, I finally found it...
It was the piece of trim inside the boot on the drivers side (above the battery) squeaking against the mounts, the top, the bottom, everything...
bloody annoying, but so glad it's gone now.
Past:
2005 Mazda MX-5 SE
1991 Mazda MX-5 NA6
Garry
Postby Garry » Thu Apr 06, 2006 10:09 pm
My car used to do that too. My subwoofer fixed it.
russs
Postby russs » Thu Apr 13, 2006 11:27 pm
My squeak has come back though I solved an earlier one... the rubber bump stop on the door frame had worn to the metal and was giving a metal to metal squeak. The rubber is very thin. I swear the squeak comes from the back suspension somewhere, like a linkage that needs a drop of oil.
Galaxy Grey NC.
rain902
re
Postby rain902 » Fri Apr 14, 2006 12:01 am
i too have this annoying squesk coming from what i think is the back left of the car - sounds a bit like rubber on glass, but its not.
i have decided that trying to identify and rectify it is more annoying than the squeak itself.
this thread is like one of those mystery sound competitions that are on the radio every so often!
