Where Has My Turret Fluid Gone???
- sab
The fluid in my gearbox turret seems to vanish after a few weeks, making the gear changes a bit more notchy.
I like the feel of the quick shift, but keep going back to the standard shifter to compensate for the loss of fluid. Even with the standard shifter, it gets a little annoying.
I have new rubbers/boots and the shaft of both shifters are well sealed, so the fluid isn't escaping via the shifter.
Where does the fluid go? Does it leak into the gearbox?
Does anyone know of a fix?
Thanks,
Sab
Thanks,
Sab
- godfather of saké
I have the same issue...I suspect the turret itself is not integral to the gearbox but might be a bolted-on thingy. And if so, maybe the gasket (assuming there is one in the join) has failed and that's how the oil gets out?
- sab
Steve Tinker wrote:sab - you can substitute the turret oil with a high moly grease or a grease / oil mix to help retain the "lubricity" of the ball joint and not lose the fluid.
Thanks Steve. I've tried that too, but it tends to thin out after a while and loses its effect. Definitely helps a little though.
Are you using a high moly grease (molibdium disulphide) or a lithium high temp grease which should both retain its viscosity above 100 degrees C. They not too expensive. If you are using normal grease, it will thin out - but you should not be losing it as quickly as you suggest - any tell tale oil marks around the exterior of the turret ?
Castrol HTB - 200 deg C.
Castrol LMM - 100 deg C.
Steve
Steve
- sab
Can't remember which brand I'm using, but it's the high temp moly stuff.
I don't think it so much melts away, but rubs away with the constant movement of the shifter ball.
No tel tale signs around the turret or gearbox either.
My guess is like what Babs said - that a seal or gaskit has worn and is leaking into the box itself.
- jules
- Guitar Hero
Jaron wrote:I had the same problem... took it to the mechanics turns out to be a faulty slave Cylinder or maybe a leaking master..
Huh????????
That's clutch dude, not turret.
Jules
- sabretooth
- Craig
- Vehicle: Non MX-5
- sabretooth
Search function works
I'm going to the local mazda dealer tomorrow to order a new bally thing at the bottom of the shifter, should I also enquire about a new gasket for the turret, or is it a lot of work getting to where the gasket goes?
Will get some high temp lithium grease while I'm out aswell. Notchy box is giving me the shits
- godfather of saké
Adam_NAclubman wrote:Search function works
You want an "inner turret boot". That's the one that usually goes, and if you are replacing the bally-thing it's only a few more mins work to replace the boot as well.
Users browsing this forum: No registered users and 46 guests
