clear front plastic parker casing-BEFORE & AFTER pics up
- JSE
im after those clear front indicator/parker casing things for the NA. I want some that are clear and dont have the orange all through them...
anyone know where i could get some from?
cheers
cheers
- green_comet
- Car Detailing Guru
you can pull the ones you have apart...
I did it to mine with a flat blade screwdriver and a hairdryer. The orange bit inside is just held in with 2 screws, You should try it, very easy to do will take you an hour or so. I also swaped my indicator with my parking lights, so now the indicator is on the outside where the parkers where.
Heres a step by step guide for you, if your interested.
http://www.mx5club.org.nz/maintenance/driving_lights/
Heres how it looks on my car.
cheers
Ryan
cheers
Ryan
- MxJadeMonkey
- Astroboysoup
hey yeh thats great.. if i get a chance this weekend i'll probally do that too...
I've been told that on later model cars you can just swap them over but im sure on mine i have to cut the wires and swap them over. I already did some slicing of the wires for my halo head lights.
AustCars.net - It's like Facebook but for cars!
- green_comet
no worries guys, i just cut the live wires and swaped them around. The ground wires you dont have to worry about... Just be very carefull when removing the clear plastic cover on the lights. Dont pull on it too hard otherwise they will snap/crack, take your time and use the hairdryer to loosen the glue up.
I also purchased some narva orange bulbs as pictured, for the indicators.
You can get them a pair at autobarn, or somewhere similar for about $3.
The bigger bulb that was used for the indicators is fine to use as a driving light..
*please not* your indicator will blink at a faster rate, after doing this modification. Because there is less current being used to run the blinkers, (because the of the smaller bulbs) the opertaion of them will speed up.. to about the same speed as when one of your globes are blown... but its well worth it..
good luck.
cheers
Ryan
good luck.
cheers
Ryan
- rodent
- 강남 스타일
green_comet wrote:*please not* your indicator will blink at a faster rate, after doing this modification. Because there is less current being used to run the blinkers, (because the of the smaller bulbs) the opertaion of them will speed up.. to about the same speed as when one of your globes are blown... but its well worth it..
I've heard this happens with some other mods involving the indicators (eg LED conversion) too. Won't wiring a small resistor in line solve this?
jonno.
- green_comet
- jules
- Guitar Hero
clear front plastic
If you want to get around the speeding up of the indicator try my method. Swap the bulbs around but spray the indicator bulb with clear lacquer and while still wet roll in powdered orange glass (available from hobby shops - they use it for copper enamelling). Keeps the same blinker rate and orange is much brighter than the "clear' bulbs you can buy. Only trouble is you have to reshape the insert hole slightly to fit the bulb.
NB SE, NA 1.8.
- ZenArcher
- green_comet
- rain902
re
clear front indicators, purpose made.
http://www.mx5parts.co.uk/product_info.php/products_id/942
also, has anyone used the 'invisible' chrome coloured bulbs that light up orange?
2013 Australian hillclimb champion 2F
2013 qld hillclimb champion 2F
Qld & Aus 2F state record holder-mt cotton
2014 vic hillclimb champion - 2A
