HELP! Cant separate upper A arm from hub!
Hi everyone. Hope we're all enjoying this awsome day outside (Brisbane anyway)
I'm fitting my new coilovers only I've run into a problem. As the topic states, I can't seem to separate the upper A arm from the hub. In fact all the ball joints connected to the front hubs are seized!
Have tried shocking the parts apart with a hammer and even got desperate and used the separater fork which destroyed one of the boots. Anybody have any ideas? Please help! I'm running out of light and I really need this done. The rears were an absolute breeze but these frozen balls joints have taken at least 3+hours out of my day.
- Boyracer
- MX-5 Encyclopedia
- godfather of saké
Why don't you remove the bottom instead?
Leave the ball joint attached to the upright, and remove the bolt that holds the upright to the lower arm. Unbolt the shock, prise the lower arm down a bit and you will see a second bolt hidden inside the arm. Undo that bolt and the upright will slide out of the lower arm without removing either balljoint.
Of course if you've buggered one of the boots it'll have to be sorted eventually
THANKS A MILLION BABALOUIE & BOYRACER!
Your advice worked a treat Finished up in the workshop and even managed to clean up the tools by 7pm. Gonna take it for a light burl later to let them settle and get a bit used to the new ride. I reckon I'd still be pondering what the hell to do if it wasn't for both of yoiur advice.
Any clues on how I'm going to separate the upper A arm from the hub? Seeing as though I got impatient, used the fork and busted up that upper boot, it looks like it's going to need replacing in the near future.
Thanks again guys
Thanks again guys
- godfather of saké
V-Spec wrote:Any clues on how I'm going to separate the upper A arm from the hub? Seeing as though I got impatient, used the fork and busted up that upper boot, it looks like it's going to need replacing in the near future.
Yeah.....you give it to a mechanic, and then walk very far away so that you can't hear the sounds he will make when he hits it with a really big hammer
- Matty
- Boyracer
- MX-5 Encyclopedia
- Garry
NOOOOOOOOO! Seems like the general advice is a BIG HAMMER. With my shonky aim, I'd be closer to doing panel work than suspension work
Thankfully Mr Generous Anonymous has offered me the use of a job specific tool to fix this. I won't mention his name for privacy sake but he can post if he wishes.
Thanks again for everyone's input on this Has made the coilover experience just that little bit better!
PS. The MX is truly ALIVE in every aspect now. Bang for buck, I can only imagine this to be the most rewarding modification
- godfather of saké
Hmmm...what sort of coilovers are those?
- godfather of saké
Nah, just didn't recognise them, that's all
Users browsing this forum: No registered users and 163 guests
