Hi, I have a big suspension dilemma. I have a 89' NA6 and when I got it it had King springs and some aftermarket shocks (not a brand I know, but I'll check on it soon). Ride is very bouncy so I figured that the shocks might have gone. Then my friend notices that the Kings look overly compressed, but I'm not 100% sure of this. So could it be the shocks that are worn or the kings have worn or a combination of both?? I would naturally think the springs will last way longer than the shocks. I would be devistated if I had to replace both.
If anyone has pics of their rides with Kings installed, can you send them to me?? My email is slugoid@hotmail.com. I'm not sure if that's a good way to see if my springs have sagged or not. Would places like Pedders be able to find out??
These questions are driving me nuts....any reply will do! Thanks.
Supension dilemma
- StanTheMan
- StanTheMan
Also check hts
measure from centre of wheel to the centre of the rear lip of fender
I'll measure it as well tonight.....
- StanTheMan
- Garry
- StanTheMan
Not exactly sure, but prob not since it doesn't look as low as yours, and I have 16's on. Pic:
http://members.optusnet.com.au/slugoid/IMG_0006.jpg
More good news. I actually have KYB Super Special shocks on (sold on Japan only)! Although I'm not 100% sure because on the website they are silver, but mine are white. At least I know they are some sort of KYB adjustables and if worst comes to worst, I can go revalve them.
- JBT
Slugoid wrote:Why is the drivers side lower?? With the driver in it will be even lower....wouldn't it be better if the drivers side was slightly higher?? I dunno, I'm not an automotive engineer.
The car is old, probably had one occupant (driver) most of the time and thus the springs have sagged. Mine was like that too but new springs fixed it.
- Vehicle: ND - 2
If we assume that you have King Lows in there and not replacement OEM's from King Springs, then yes the spring will look compressed.
Your problem is caused by the rebound of the spring not being dampened by the shock absorber. So a cheap Monroe w/- a King low spring will always bounce a little, even if the shock is brand new.
What you need is to upgrade the shock to something better. Minimum would be Monroe GT gas, preferably Koni or KYB - something of a better calibre than the ole cheapo shock.
r0gue wrote:If we assume that you have King Lows in there and not replacement OEM's from King Springs, then yes the spring will look compressed.
I think I have King lows (yellow). I've realised that the main problem was with the shocks, but could sagged springs contribute to more bouncing? That was my main concern. From what I know so far, my springs are ok, just the shocks. Then I found out that my shocks are set to the softest setting (KYB Super Special). So for now i've set the shocks harder and see that happens. At worst, a rebuild or new shocks. I was worrying that the springs might have gone too, which would mean more $$.
- JBT
Slugoid wrote:I think I have King lows (yellow).
Colour is no guide - mine are yellow but standard ride height.
Slugoid wrote:........but could sagged springs contribute to more bouncing?
Nope, the shocks stop the bouncing - that's their job.
- sabretooth
Tons of pics of Kings + Konis here: Shocks - Koni adjustables install (NA).
On the coils of your springs, look for a small tag on the springs (take the wheel off if you have to). The model number should be there, eg KM-FL52. These will tell you which model spring you have.
Users browsing this forum: No registered users and 183 guests
