Im interested in getting these rims to use on track days, does anyone know if they are too wide to use, or if the will scrub?? the rears are 15x8 +26 offset, and fronts are 15x7.5 +35 offset...
any help is very appreciated.
cheers
Ryan
Dubly wrote:If you're keen to get them on, you could get them to fit. You would need to find a decent machine shop and get them to take 10-15mm off the center of the rear wheels.
Dubly wrote:Babalouie,
Wheel companies don't make a different cast for each offset. They make one and machine it down to specific offsets. So, on a wheel with a offset of +26, if you remove 10mm you now have a offset of +36.
In your case, you likely have a offset of +40 or 45 and if you took 10mm off you would be into the wheel studs.
Very few cars run offsets higher then +45 other then a few exceptions. ie. Subaru's, Corvette's, etc...
