QR Trackday - 21/02/2006 Invitation - Entrants Listing
Moderators: timk, Stu, zombie, Andrew, -alex, miata, AJ
- rhysk
- sabretooth
rhysk wrote:Look for the black NB
Ooh, someone got the newie he was talking about on the Glasshouse Mountains run!
- sabretooth
- JBT
- sabretooth
- rhysk
- Cal
- rhysk
The only times I saw posted were for the Clubman track.
Mike was fastest, putting in a 1:08.xx and mostly hovering in the 1:10s
Tony was doing brilliantly, and got down to something like 1:10.1x
I was running 1:10's, which I am happy with, but brake fluid was stuffed so my lap times drop off considerably after the first two.
There will be details on http://www.timeattack.com.au/ at some point I assume....
- npn4875
rhysk wrote:Mike was fastest, putting in a 1:08.xx and mostly hovering in the 1:10s
Oi!! on the last session I did four laps in a row, *all* 1:08.something - very consistent!
...as he always does, that's one of the fastest non-blown MX5s on a track with him at the helm. He was the same at Morgan Park. Coulda been faster today too, but his new rear suspension setup was proving a bit unsteady under brakes.
I'll post elsewhere on the appropriate threads, but I can report that the Fulda Extremos held up extremely well, as did my new Lucas/TWR brake pads - excellent. Even if they stunk a bit of burning resin till they bedded in properly ;) Oh yeah, and they lived up to their "lotsa dust" reputation.
Really great day out. Well done the organisers.
Mike
Every k over is propaganda
Black SP
Black SP
- sabretooth
rhysk wrote:The only times I saw posted were for the Clubman track.
Mine too. They're all spongy, and the fluid is black! Mind you, it's been black for months, but the track day's made the brakes reallllly spongy. I really really need to do that fluid change now.
Also, I think I've finally found my oil leak - the second dipstick that's on the oil pump - it has one because the engine block is from a Familia. I'll probably pull the dipstick seal the hole up with some Selly's Knead-it (or other similar metal putty).
- sabretooth
npn4875 wrote:...as he always does, that's one of the fastest non-blown MX5s on a track with him at the helm. He was the same at Morgan Park. Coulda been faster today too, but his new rear suspension setup was proving a bit unsteady under brakes.
Mike
I concur. The man has some serious ability.
Mike, I've been going over the pics and you've been getting some serious lean happening in the corners.
- rhysk
- JBT
- npn4875
sabretooth wrote:Mike, I've been going over the pics and you've been getting some serious lean happening in the corners.
yeah, I know.... have you seen that pic of me under heavy brakes that Rhys took at Morgan Park? You could stash your suitcase under the rear arches
I wonder what will make it lower, and flatter???? Something is coming to mind.... I'm getting a "T"..... now I'm seing an "E", wait, I'm sure the next letter is "I"......
Just got to convince the manageress
Black SP
Black SP
Users browsing this forum: No registered users and 99 guests
