Is there a best way to rejuvenate suspension?
- Garry
New "quality" shocks will help considerably, and are easier and much cheaper than replacing your suspension bushes. Stay away from generic brands like Pedders or Monroe and go for something like Koni Yellows or KYB AGX's. They are a bit more expensive but the final result will be worth the extra money. You get what you pay for.
- Andrew
Garry wrote:New "quality" shocks will help considerably, and are easier and much cheaper than replacing your suspension bushes. Stay away from generic brands like Pedders or Monroe and go for something like Koni Yellows or KYB AGX's. They are a bit more expensive but the final result will be worth the extra money. You get what you pay for.
+1 vote for the KYB's -
- bigdog
- King of the kennel
- Andrew
Even though i've never had either on my MX i'd go for Koni over KYB.
Perhaps their product have improved recently but i'd read more people "upgrade from KYB to Koni" then the other way around.
Who here has dríven on both?
I went for the Tein Flex, one of the best features of the MX-5 is handling, I wanted a setup that could accentuate that.
Given the amount of kms on your MX-5, almost anything will feel better.
The Tein Super Street is about $500 more expensive then a Koni/King combo (new), so unless you're on a very tight budget splash out a little and get them
Flog your king springs to a forum member.
- Garry
I've tried KYB AGX's and Koni yellows on an NA. I thought the AGX's felt better, and they are very easy to adjust if a little noisey over speed bumps. Having said that I luuuurve my Koni's on my NB8B.
- tk421
Re: Is there a best way to rejuvenate suspension?
rogerbid wrote: I have to say the only time it shows any sign of its age (137,000kms) is when riding over poor road surfaces and in particular when crossing the ridges from the roadway into a driveway etc. I have not yet had a Pedders suspension check carried out, but am thinking of doing so to see what they recommend.
Hi Roger,
Just to clarify is it the bouncyness of the car you have issues with? (if they are original shocks, it certainly would be)
or is it the fact that you get rattles and creaks in body over such surfaces with the bumps basically shaking the c#%p out of the car (windscreen moves side to side a little as compared to the rest of the car - known as scuttle shake)
Worn shocks will certainly contribute to that but maybe (whilst this may be a little "serious" for you) you might want to consider some chassis bracing of some sort. A few of us with 98 models have recently ordered some products of this nature. We are still waiting for them to be installed though - hoping for good results.
I have put shocks on mine as well recently, certainly made great improvements to the handling but did not improve problem 2 very much (personally scuttle shake drives me crazy
Steve
98 NB8A, Mania CAI, Eibachs and Bilsteins, Whiteline brace, Starcorp's, DBA Slotted and asstd bling, FM butterfly brace. FFS coldside and the whiiiinnne. Now 138rwkw (Glory Run
) More with tuning.
http://users.tpg.com.au/usethe4c/Green+Machine.jpg
- Matty
I've been through several suspension versions. Basically, all the "hard" bits (ie metal) don't really wear out, but the rubber and oily bits do degrade.
If you're happy with the standard ride height and soft springs, then keep them - going lower has its compromises, though it does look tasty!
The OEM shocks tend to lose their damping abilities after not too many k's - yours are surely shot by now.
A set of Koni shocks with the standard springs is a truly excellent setup for road use. In fact, it served me very well on the track too.
New bushings are also a great. I replaced mine with aftermarket urethane ones (SuperPro) - great if you want a little more performance/handling sharpness. Cost about $500 for the full set of 22 control arm bushings. They do after a while tend to generate a bit of friction as the grease wears out though (OEM rubber bushings flex and therefore don't need grease).
For the sake of longevity a new set of OEM bushings are probably a better option for you, though will probably set you back about $700+...
Then you're up for installation labour - not too bad for the shocks, but the bushings can take a while. There are people around (here and the club) who might be willing to help out with the job. Shocks are pretty straightforward. Bushings are a little more work, but not beyind DIY status.
If you're a Vic club member you can borrow (from me) a tool which is a perfect bushing press. You'll need something like it to replace the bushings - even loaning it to a shop would probably help them with some parts of the job.
- rodent
- 강남 스타일
- Matty
- Brad
Can someone explain to me if pillowball top mounts are actually needed on the MX5's with Tein SS'? I've heard conflicting advice, that as they are not a strut they don't need pillowball mounts. Are they an optional extra on the TeinSS and if so how much extra should I be looking to pay?
- Brad
Brad wrote:So what would be the advantage of a metal solid top? What's the normal one, rubber?
looks probably
actually if u don't get the metal top, u need to reuse the OEM one, which means more steps for installation.
as someone (Justin Fox i think it was) found out, you can lower your car more with the metal top than with the OEM top.
