Dark/tinted Tail lights
- Boyracer
- MX-5 Encyclopedia
Just wondering if anyone knows about either tinting the rear tail lights or getting darker ones,for NB model.
- Sean
You can buy a black tinitng paint called might shades from most auto parts stores.
Spray it lightly on the inside of the lense so the outside stays shiney. If you spray it too heavily you will never see the lights illuminate through it, which is when you'll probably run into problems with the cops/rta.
Craig wrote:EGG80X wrote:Its not illegal if you dont get caught lol
Hate to see a insurance claim rejected by it though!
Not wanting to rant here....but I get very annoyed when I see any car that has had the rear lights tinted to a point where you cannot see the brake or indicator lights. It's not just illeagal, its down right dangerous !
J
- Astroboysoup
Jsut reading throught he ADR rules.. like everyone does....
the tinting appears to be legal as long as the light emitted from the lenses is at a particular intensity.
so if the lenses are tinted, the globes have to be upgraded to emmit the right intensity of light.
ADR 49/00
Section 6 - Intensity of Light Emitted
Section 7 - Test procedure (an interesteing read)
If you do it, get the modification certified and complied and there should be no problem with insurance.
ADR 49/00
AustCars.net - It's like Facebook but for cars!
- green_comet
- Car Detailing Guru
- rain902
green_comet wrote:might be able to go pretty dark, and use some really bright led bulbs...
luxeon star bulbs with switchmode power supply should do the trick nicely there - www.jaycar.com
2013 Australian hillclimb champion 2F
2013 qld hillclimb champion 2F
Qld & Aus 2F state record holder-mt cotton
2014 vic hillclimb champion - 2A
- Astroboysoup
cooool
well there you go.. that would do the trick
I wonder if they have green globes... i need some really high intensity green ones.. no one can see my indicators... i keep getting complaints
- rain902
Astroboysoup wrote:cooool
LUXEON 1 Watt LED Star Modules - Green
Luxeon Star Power Light Sources are the world's brightest LED's offering up to 120 lumens per single source. Offering superb power and lumen maintenance, it far exceeds standard high flux LED's. Luxeon Star consists of a Luxeon Emitter mounted to a square or hexagonal submount. Luxeon Star hexagonal modules can be connected and powered in a close packed hexagonal configuration for tight spacing and increased light output per unit area.
- Highest Flux per LED in the world - up to 120 lumens!
- More Energy Efficient than Incandescent and most Halogen Lamps
- Superior Lumen Maintenance
- Very long operating life (up to 100k hours)
- Low voltage DC operated
- Cool beam - safe to the touch
- Instant light (less than 100 ns turn-on time)
- Fully dimmable
- No UV
- Superior ESD protection
- LXHL-MM1C
ZD0402.pdf
QTY
1+ $16.95
shameless cut-and-paste plug for jaycars leds - and no, i dont work for em in any way.
