Indicator driving lights...indicators flashing really fast
green_comet
Car Detailing Guru
Postby green_comet » Fri Jan 27, 2006 9:25 pm
I never liked the look of having big front indicators and small parking lights. So i decided to get off my ass and try a mod that is avaliable here:
http://www.mx5club.org.nz/maintenance/driving_lights/
Took me a couple hours to do, the worst bit was trying to take the front lenses off of the lights, but once its done everything else is simple..
I have found that after doing this mod and going for a drive that the indicators are flashing very fast when on.. any idea on what could cause this or how it can be fixed... All the globes are working.
Me
Postby Me » Fri Jan 27, 2006 9:34 pm
nice. how long does that take u? :D
green_comet
Car Detailing Guru
Postby green_comet » Fri Jan 27, 2006 9:37 pm
green_comet
Car Detailing Guru
Postby green_comet » Fri Jan 27, 2006 9:43 pm
yeah i was looking there, but the lights on the us models are different to here. The parking light and indicator both work off the same globe.. I just found it easier following the NZ instruction.. :D
fig
Postby fig » Fri Jan 27, 2006 10:31 pm
They look great, need to update your sig now. :)
Then
10AE (#3062)
Now
'08 Porsche Boxster S modified ;-b
'11 Porsche Cayenne 22's FTW
'78 Porsche 911SC - Old Skool Hotness
'67 Porsche 912 - Fav!
green_comet
Car Detailing Guru
Postby green_comet » Sat Jan 28, 2006 2:25 am
got a problem, i have been out for a drive tonight and found that the indicators are flashing very fast when there on. I tested each side and none of the globes are out...anyone know what might be wrong or how i can fix it?
StanTheMan
Postby StanTheMan » Sat Jan 28, 2006 7:29 am
I'm no sparky but everytime i've had something like that was a Dodgy earth connection.
JBT
Postby JBT » Sat Jan 28, 2006 9:11 am
Could be incompatible voltages between the bulbs if you changed any or a bad earth as STM said.
lowmiata
Postby lowmiata » Sat Jan 28, 2006 3:06 pm
Quite simple to fix the fast flashing problem...
Your indicator system flashes fast when there is a bulb blown
or in your case....
All it is is not enough indicators! ie you have removed large indicator from circut and replaced with little one!
I have same mod easiest solution is to go to a wreeker and get two side indicator bulbs and wiring from a late model car (falcon/commodore) as easiest to fit ie drill hole and file groves for the new bulb socket to fit into
i put the light into the big portion of the light ie when the lights aren't on the whole lot flashes I also upgraded the bulbs as well
EVI15 1998 to 2008
lowmiata
Postby lowmiata » Sat Jan 28, 2006 6:15 pm
Also of note if you don't want to go through the hassle of getting rid of the orange from the indicator just buy the US aftermarket replacement lenses from DEPO :mrgreen:
EVI15 1998 to 2008
smiles
Postby smiles » Sat Jan 28, 2006 10:42 pm
lowmiata wrote:Quite simple to fix the fast flashing problem...
or in your case....
Wouldn't that mean an appropriate resistor can be soldered in line to fix the problem?
