Rolling Sans Suspension..
Sean
Postby Sean » Fri Jan 27, 2006 6:05 pm
Can anyone confirm if an NA car can be moved with no suspension in it. As in pushed around and the like?
CT
Postby CT » Fri Jan 27, 2006 6:38 pm
Not unless you put a spacer such as some solid wood between the A-Arms or even between the LCA and the upper shock mount - that's how I did it. Sounds like lots of fun 8)
Sean
Postby Sean » Fri Jan 27, 2006 6:41 pm
CT wrote:Not unless you put a spacer such as some solid wood between the A-Arms or even between the LCA and the upper shock mount - that's how I did it. Sounds like lots of fun 8)
Cheers CT,
I knew someone had done it with wood. Ah well, time to go chop some wood...
Users browsing this forum: No registered users and 211 guests
