Removable Head Units
CT
Postby CT » Thu Jan 26, 2006 10:15 am
Remember the old days before detachable face head units and you could buy units that you slid out and took away with you - like a small black handbag :roll: . Anyway, does anyone know if you can still purchase this type of head unit?
EGG80X
Postby EGG80X » Thu Jan 26, 2006 10:21 am
I seen only on cheapo brands @ JB Hi Fi, its a bit of shame they dont make them anymore...... Its a pretty good idea for our cars
STV
Postby STV » Thu Jan 26, 2006 1:02 pm
i read a thing about them a while ago.. i believe that they are no longer made as when people stopped bothering to remove them, someone else helped themselves to them!
I do agree that they would be a great idea for the mx, but why not just a detachable face?
Where is 'Home Sweet Home'?
CT
Postby CT » Fri Jan 27, 2006 8:18 am
It's for a road registered race car. It would be nice to be able to pull the whole thing out at the track, otherwise detachable face it will be. Cheers :D
Matty
Postby Matty » Fri Jan 27, 2006 8:46 am
fitted using a slide-in mounting bracket, any head unit should be easy to remove quickly (with the little removal tools!). just undo 2 or 3 plugs at the back and it's out!
Agro
Postby Agro » Wed Feb 01, 2006 8:27 am
CT, I have a stereo which has the removable face unit. I am thinking of upgrading, but need to do some research when I have 5 minutes to myself. I want to try and keep the amp, speakers and stacker, but not sure if a new head unit will be compatable.
Bottom line is if you aren't in a hurry, I can look into it and sell you mine....
How would I know, I'm only a puppet!
Postby Okibi » Thu Feb 02, 2006 3:35 am
Alpinehave a the "FantomFaxe XL" model with "Anti Theft Detachable Face"
CDA-9855R
Their "Classic" range has "Anti Theft Detachable Face" too
CDA-9847
CDE-9845
CDE-9843
CDM-9821
CDE-9841E
CT
Postby CT » Sun Feb 05, 2006 9:54 pm
Agro wrote:CT, I have a stereo which has the removable face unit. I am thinking of upgrading, but need to do some research when I have 5 minutes to myself. I want to try and keep the amp, speakers and stacker, but not sure if a new head unit will be compatable.
Hi Agro - sorry for the late reply but I am definitely in no hurry. Won't be needing anything for at least two months. Although I just found a head unit that takes USB sticks for MP3s - that might nearly be a good result. I'll let you know. 8)
